Spare Tire question
At least my daughter's car now has a spare !!
I don't know what would fit....Maybe from a later model Camaro or Firebird???
You can carry a baby spare IF you put it on the front ONLY. And IF it has the correct backspacing to clear your brake calipers, which I doubt it would. And then, if you have a flat on the rear, you must put the spare on the front and then put that front wheel (same size as rear or all bets are off) on the rear.
Tire width makes no difference, but diameter is critical.
And then..(yuk yuk
)..If you have sucked up the spare carrier assembly to hold the baby spare, where are you gonna carry that full size flat tire 'till you can get it fixed?? Dang, whatcha gonna do now? Tell your girl to ride on the back deck 'cause the tire has to sit in the passenger seat??
I gay-ron-tee several folks will pop up with "Fix-a-Flat" and/or "call AAA on the cell phone." That's all very well and good if you only travel in areas with 100% cell phone coverge and 24 hour AAA tow trucks, or only drive on sunny weekend afternoons to car meets when you might run over a thumbtack.
Well in my experience, the situation where you get a flat tire is more like midnite when it's 30 degrees out with a 35 MPH wind blowing, you are running a mountain pass or plains stretch where there is no cell phone coverage for 25 miles in either direction (and the tow truck wouldn't get there 'till sometime after 10 the next morning anyway), and you run over a chunk of rusted exhaust pipe laying in the middle of the road and it put 3" gash in your sidewall so your "Fix-a-f**king-Flat" won't do any good anyway.
Whatcha gonna do then?
Give me a full size spare tire any day...(And be sure you can undo the lug nuts that the bozo at 'Big-O Tire' put on with a 200psi air wrench with your piddly-a** little OEM lug wrench as well....!)
"Just My Opinion"
John
Spike
Keep the full size spare!
