Flat tappet cam failures
Old Jan 5, 2008 | 08:02 PM
skipinhouston's Avatar
skipinhouston
Default Flat tappet cam failures
I'm sure the people on this forum have already addressed this problem, but after losing cams in a couple of high dollar restorations (both big block Mopar's) I've been doing, I called Comp Cam's about the problem and they have a bulletin they send out (apparently my ego/ ignorance/ stupidity caused me not to read them) with each cam shaft warning of problems with modern oil in flat tappet cams and new oil formulations.
Who knew?
Engine break in with their oil additive is highly recommended and they specify Rotella T (diesel truck oil) as the standard for our use.
I'm sure the name brand equilivants would work too if you have a brand preference.
I changed to this schedule and haven't had a problem since. In fact, I use a couple of ounces of the additive when I change my oil just to be safe. I know its expensive but it only takes a little, and engines are expensive too.
I hope haven't wasted to much space here and this saves someone a camshaft.
Skip in Houston
Old Jan 5, 2008 | 08:08 PM
jerrylee's Avatar
jerrylee
Hey Skip when your cams went how many miles did you have on your engine......I have around 3,000 on my rebuild n so far so good....Thanx..Jerrylee///
Old Jan 5, 2008 | 08:15 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Old news here. Flats tappets MUST use zinc additives or you risk catastrophic cam failure. This is one reason many have switched to rollers on their rebuilds.
Old Jan 5, 2008 | 08:26 PM
jerrylee's Avatar
jerrylee
If you change from flat to roller what else has to be purchased besides the cam n lifters...Thanx...Jerrylee///
Old Jan 5, 2008 | 08:27 PM
OzzyTom's Avatar
OzzyTom
The new formulations of automotive oil have changed.....
here is a question asked of Mobil.......
http://www.mobiloil.com/USA-English/...otor_Oils.aspx
Zinc/Phosphorus levels were reduced to improve catalytic converter efficiency/life.
A few guys in our club use diesel oil in their older muscle car engines as Diesel oil DOES contain higher levels of zinc/phosphorus.
Old Jan 5, 2008 | 08:28 PM
gkull's Avatar
gkull
The best alternative is if everybody would quit buying junk pot metal cams from Comp Cams.
Comp cams got me a couple of times and you are not supposed to say anything on a forum. But they "CC" just don't care!
Old Jan 5, 2008 | 09:07 PM
ratflinger's Avatar
ratflinger
You'll also need a cam button to keep the cam from walking & might as well get roller rockers. (shafts if you can afford them) Pushrods will have to be checked for correct length. (I'd replace them)
Old Jan 5, 2008 | 10:11 PM
Ironcross's Avatar
Ironcross
A expensive rev kiit, to keep those heavy lifters on that expensive cam.
A really good set of double valve springs, to keep the valves from floating..
A compatible distributor gear, to keep from distroying the distributor gear.
At least a button for the timing cover, to keep the roller cam from walking around {back and forth}
A set of compatible push rods, compensated for the added length of those heavy roller lifters.
Cut your valve guides,
A set of new retainers,
Simple wasn`t it, thats all thats too it...
Old Jan 5, 2008 | 10:58 PM
BigBlockTank's Avatar
BigBlockTank
Not all roller cams require double springs. In fact I looked at one today that said NOT to use double springs. So the best bet is to check with the company that makes the cam.
Old Jan 6, 2008 | 12:19 AM
Ironcross's Avatar
Ironcross
those that are any good do!
Old Jan 6, 2008 | 12:23 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Good one!!!
JIM
Old Jan 6, 2008 | 03:52 AM
Solid LT1's Avatar
Solid LT1
DON'T USE Diesel oil in a high RPM gasoline motor, you are a FOOL if you do, besides, they are removing all the ZDDP from Diesel oils too. Some oils for you to look up/use: Brad Penn racing (NO! it's not Jeff Spicolli's brother!), Joe Gibbs oil, Motul (really EFFING expensive!) Mobil1 MOTORCYCLE oil, Valvoline Racing "not for street use" oil, any oil with a high ZDDP additive package (ZDDP is Zinc extreme pressure lubricant, Zinc=Lead=fouled catalytic convertor so the ZDDP is being eliminated from all oils INCLUDING Rotella for the new Diesel motors with catalytic convertors.) I do like Rotella in my truck, it has a little silver badge on the side "Duramax/Allison" that says it all
Old Jan 6, 2008 | 08:32 AM
tt 383's Avatar
tt 383
has anyone had any luck with an EDM lifter? maybe this would stop the wiped lobes?
Old Jan 6, 2008 | 09:49 AM
jim2527's Avatar
jim2527
If they're not a vendor you should be able to bash them all you want...
correcto...
If you do a search theres good threads about this. There are alot of gasoline oils out there with the old formulation. In fact Mobil has just re-released an oil to specificaly adress this isssue. Most high mileage oils have the high zinc.
Some linkages for you:
http://forums.corvetteforum.com/show...3&postcount=10
http://forums.corvetteforum.com/show...8&postcount=11
Old Jan 6, 2008 | 09:57 AM
js292's Avatar
js292
I just use Rotella and GM EOS for break in and have had no problems. Knock on wood
Old Jan 6, 2008 | 10:07 AM
mrvette's Avatar
mrvette
Pity of it is, catasstrophic converters are one of the largest automotive frauds ever pulled off on the public....for non existant reasons.....now we can't even get decent OIL anymore....gone well beyond stupid...to the sublime....just ANYTHING to kill off old cars and force sales of more 30,000 dollar POS 'cars' on the public.....
Old Jan 6, 2008 | 10:25 AM
JoeRags's Avatar
JoeRags
Shell still sells the "old" formula Rotella.
Guess I'm a fool.
To Flat tappet cam failures
Old Jan 6, 2008 | 10:26 AM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
Now they want everyone to buy Hybrid vehicles...and next they'll want us to buy all electric vehicles. HEY WORLD! Wakeup, there is plenty of oil to go around for many years to come. Oh yea, like we're going to really produce more gas with corn? As for automotive emissions; what a load of balogna! It's the same silly effort with the R-12 Freon conversion nonsense.
OK, now that I've ranted on one of my many pet-peevs, I feel much better now.
Old Jan 6, 2008 | 10:46 AM
Artsvette73's Avatar
Artsvette73
It took them 37 years to find out zinc was killing cat. convertors? I think it is Big Brother, along with Green Sleaze way to kill the Old car enthusist hobby. Start buying up the roller blocks.
Old Jan 6, 2008 | 01:37 PM
69ttop502's Avatar
69ttop502
Don't use Valvo NSL thinking it has any ZDDP. Saw a Virgin analysis on Chevelles and it was not even close to being enough. Even the newer CJ4 diesel oil still has alot of ZDDP, just not quite enough of accepted minimums. Diesel oil also is higher in detergents which may help wash more of the good hings off our lobes. I agree with the Brad Penn and Joe Gibbs.
