Pressure bleeding W speed bleeders
Old Jan 5, 2008 | 11:28 PM
gve's Avatar
gve
Default Pressure bleeding W speed bleeders
Has anyone pressure bleed their brakes with the speed bleeders installed in the calipers. Would I need to remove them, or would I need higher pressure to move the spring in the calipers?
Old Jan 6, 2008 | 12:56 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I just pressure bled my brakes with a speed bleeders all around, not a problem, in fact I only pump to 12 PSI or so and its enough to do all 4 wheels.
Old Jan 6, 2008 | 09:53 AM
Durango_Boy's Avatar
Durango_Boy
Mine are called check valve bleeders, but do the same thing as speed bleeders and I just leave mine in.
Old Jan 6, 2008 | 11:30 AM
75 Red Vert's Avatar
75 Red Vert
Just leave them in. Makes for easy one man bleeding. I use a vacuum pump hooked to the speed bleeder and just pump away until I get no bubbles. Then put the vacuum pump away till I need it in another 20 or so years. Then I won't even remember where I put it.
Old Jan 6, 2008 | 11:32 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Me, too.
Old Jan 6, 2008 | 01:31 PM
gve's Avatar
gve
Thanks for the replies,now I know that I won't have to replace them.
To Pressure bleeding W speed bleeders
