control valve housing bad ?
Old Jan 6, 2008 | 11:46 AM
tak82's Avatar
tak82
Default control valve housing bad ?
I have noticed all the steering components are tight EXCEPT the ball stud in the control valve. The valve isn't leaking, and upon tear down of the valve, the ball stud and the cups are actually in good shape. This is on a 82, I'ld say it's a rebuilt unit. With all pieces cleaned, the sleeve has some play in the housing, it rocks up and down in the back part of the housing. Niether look worn, (ovaled,etc.) would I be correct in saying the housing is bad ? How much play should there be ?
