1980 Wiper Problem - Won't stop
Old Jan 7, 2008 | 01:59 AM
Aspenglade's Avatar
Aspenglade
6th Gear
Default 1980 Wiper Problem - Won't stop
When I start my car, my windshield wiper on my 1980 Vette won't stop running. It's not the motor. The motor is new. I thought it was the switch and replaced it, but still have the same problem. Although, sometimes when I turn off the ignition and switch it back on, it may stop...and at other times doesn't.
1. Could it be a relay?
2. Whereabouts can I locate the relay in the vette to remove and replace?
3. Any one know the part number?
Thanks, appreciate your help!
Old Jan 7, 2008 | 08:42 AM
Luster's Avatar
Luster
The wiper relay is in the storage bin behind the right seat.
I don't know the part number.
Old Jan 7, 2008 | 10:55 AM
tomard's Avatar
tomard
Default Wiper Relay
It is in the jack compartment, up against the back of seat (inside compartment). I will send you PM with contact info for a CF member that greatly helped me out with relay problem, as those are not manufactured anymore and have to be fixed (if the relay is your problem).
Old Jan 7, 2008 | 02:45 PM
dalewilson99's Avatar
dalewilson99
yup sounds like the wiper controller. There is a circuit that turns the wipers on for a few sweeps when the washer pump is started. The transistor for that circuit sometimes shorts out. If you are handy with a soldering iron I can walk you through, or, you can send the wiper controller to me to fix.
Dale
To 1980 Wiper Problem - Won't stop
