Adjustable Clutch Fork Ball Stud
Old Jan 8, 2008 | 04:26 PM
SLVRSHRK's Avatar
SLVRSHRK
Default Adjustable Clutch Fork Ball Stud
I'm in the process of rebuilding my powertrain and have changed the flywheel to a lightweight aluminum one. The new flywheel is thinner than the stock flywheel, which necessitates changing the clutch fork pivot ball stud height.
I'm using the same clutch that was in the car (new, but ACDelco replacement) so the clutch/pressure plate height from the flywheel should be the same as before. Is figuring out the new height as simple as making it equal to the change in thickness of the flywheel? If so, I'm assuming it should be adjusted longer by that amount, is that a correct assumption as well?
Just don't want to have to remove the tranny after we put it all back in the car (going in as one assemble drivetrain).
Old Jan 8, 2008 | 05:21 PM
gkull's Avatar
gkull
GM p/n 3790556 long 1.680
At your local Chevy-GM dealer. About $13 with tax at my Pontiac dealer.
I have a thinner lightweight flywheel and the block saver plate. so I tried those adjustable wonders from Summit for $48 and figured out that GM made two Pivot ***** - the longer for a thinner flywheel
Old Jan 9, 2008 | 08:48 AM
SLVRSHRK's Avatar
SLVRSHRK
Many thanks!
Old Jan 9, 2008 | 10:24 AM
Surfer69's Avatar
Surfer69
Be careful. I just did this with a thinner flywheel also. The flywheel was .200 inches thinner so I thought I would adjust my adjustable stud by .200 longer than the short one that was in there. After installing, it looked like I didnt have enough play at the fork and I thought I was too long. Well after 3 tranny pulls it ended up adjusting to the longest position I could tolerate and still have some thread left at the threaded adjusting rod connection at the firewall. Point is, if you go with GM long there is no adjustment but you might get lucky if it worked out OK. If not, you'll be pulling the tranny.
I would measure the difference between flywheel thickness and extend your adjustable pivot stud a hair more than that difference. Assuming your new flywheel is thinner and you have room on the threaded rod.
Old Jan 11, 2008 | 09:54 PM
vintage-racer's Avatar
vintage-racer
Default Lakewood pivot ball
I've used the adjustable Lakewood pivot ball from Summit (LAK-15501) $16.95 on 2 of my C3 swaps and found it to be the hot ticket for clutch pivot issues. I adjusted it to a little over half of its possible adjustment which is significantly longer when compared next to the stock short ball. I can now back off the fire wall pushrod , and have much more adjustability under the hood. My Stingray has had this piece for 9 years of driving, it's a great product.
To Adjustable Clutch Fork Ball Stud
