Bench bleeding
Old Jan 8, 2008 | 09:31 PM
ebertthebull's Avatar
ebertthebull
Default Bench bleeding
Is it nessasary to bench bleed a master cyl. when you are starting from scratch? I. E. new cyl. lines, and calipers? It seems that since your going to be purging the whole system you might just as well do the whole thing at once. But I'm not sure. I'm leaning twards silicone fluid , if that makes a difference. Thanks...Ron
Old Jan 8, 2008 | 09:47 PM
dannyman's Avatar
dannyman
If changing the master cylinder, then yes, bench bleed. Bench bleeding is a way to evacuate air from the master cylinder because you are able to bleed it in a horizontal position, which is not possible when installed in the vehicle.
If changing lines and calipers and the master cylinder has not been drained then you should be fine just bleeding the whole system without bench bleeding the master cylinder.
Old Jan 8, 2008 | 09:48 PM
Peterbuilt's Avatar
Peterbuilt
Yes you have to bench bleed the MC first, and Dot 3 fluid might be best. PG.
Old Jan 8, 2008 | 10:36 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yes you must bench bleed the master cylinder or suffer the fate of endless bleeding
Old Jan 8, 2008 | 10:39 PM
vettecrazy88's Avatar
vettecrazy88
bobs77vet is sooooo right. Please don't ask me how I know. I still have nightmares about it.
Old Jan 9, 2008 | 04:33 PM
ebertthebull
Sorry I did'nt make it clear the master cylinder is new also . The entire braking system. I changed over to manual from power, so I'm starting from scratch
Old Jan 9, 2008 | 05:46 PM
dannyman's Avatar
dannyman
Then yes, definitely, bench bleed.
Old Jan 9, 2008 | 06:22 PM
ebertthebull
Ok thanks...Ron
Old Jan 10, 2008 | 06:56 AM
RunningMan373's Avatar
RunningMan373
def bench bleed the M/C, with the recirulation method, stay away from silicon fluid,, too many negitives and too hard to change back. go with some synthetic valvoline dot 4, same as dot 3, only higher boiling point, and lasts longer.
Old Jan 10, 2008 | 08:45 AM
jim2527's Avatar
jim2527
Originally Posted by RunningMan373
def bench bleed the M/C, with the recirulation method.
You can buy a recirculation bleeding kit from NAPA if your M/C didnt come with one.
NAPA # 700-1132
http://forums.corvetteforum.com/show...ight=kit+bleed
To Bench bleeding
