Electric Water Pump on the street?
Old Jan 9, 2008 | 01:53 PM
enkeivette's Avatar
enkeivette
Default Electric Water Pump on the street?
Who has got them? What kind of motor are you running? Radiator? Do you have cooling problems with them sitting in traffic or cruising on the freeway? Do any of these have provisions for a heater hose?
Will I need a higher amperage alternator to run one of these? I'm already running electric fans.
Old Jan 9, 2008 | 02:58 PM
davidm_comp's Avatar
davidm_comp
I wouldn't rely on the stock alternator to run both electric fans and a electric water pump....would make the upgrade to the CS144, '96 Impala one fits fine with a minor mod to the wiring, I have it in my '77 and it works great....DurangoBoy has a write up on it I think
Old Jan 9, 2008 | 04:44 PM
enkeivette's Avatar
enkeivette
But how about cooling? Can an electric pump provide adequate cooling for street driving?
Old Jan 9, 2008 | 05:45 PM
FB007's Avatar
FB007
More than likely yes, but what are you going to do when it craps out on the road?
Old Jan 9, 2008 | 05:50 PM
vetteaddic's Avatar
vetteaddic
I'm running a Miezere on the 427 sb with no problems,temps stay at 180 but does climb when I blast down the hyway, and I mean blast!
And its the one with a pully for my serpentine belt.
[IMG][/IMG]
Old Jan 9, 2008 | 05:51 PM
FB007's Avatar
FB007
[IMG][/IMG]
Your just overheating because you have no radiator. You really should put one in.
Old Jan 9, 2008 | 06:45 PM
Daffy2's Avatar
Daffy2
Default Elect. water pump
Always an interesting discussion and here's my input:
My son has a Fiero that we put a well built 350 into. There are hundreds of Fiero V-8 conversions using electric water pumps. All seem to run cool (ours runs 190* on a scalding day). The pumps are generally Mezzuire and CSR. Most are driven heavily, my son's car is driven on a daily basis, and with some spirit.
There are no reported problems that I'm aware of, the electric pumps work fine. I think that electrical failures that might cause you to be stranded are about the same as electronic ignition or electric fuel pump failures.
Just my experience.
Daffy
Old Jan 9, 2008 | 07:33 PM
enkeivette's Avatar
enkeivette
I've just heard that electric pumps aren't sufficient for cruising (sustained rpms) as they only spin at one speed and don't match the speed of the engine.
I was thinking about getting a Proform unit. But now I'm second guessing it because I'd have to find a different passenger side alternator mount, as mine bolts to the water pump. And I'd also have to upgrade my alternator.
Vetteaddic, does the temp climb if you're just cruising on the highway?
Old Jan 9, 2008 | 07:41 PM
ZL1powr's Avatar
ZL1powr
One of my buddies is using the Miezere pump in his 70 with a 496 that dynoed at over 650 HP. I was a skeptic but he has never had an issue. It always runs cool and has been reliable.
Old Jan 9, 2008 | 08:30 PM
76 sting's Avatar
76 sting
Dual spals, proform electric, alt will absolutly need to be upgraded
mine all work great on the street, but I have never cruised more than 45 min at a time.
Old Jan 9, 2008 | 11:50 PM
1981Z06Vette's Avatar
1981Z06Vette
I'm running a Mezeire with the LT1 in my 97 Camaro SS (Be Cool Radiator), and it works great. There was a slight power increase, and it cools the 383 with no issues even in heavy traffic. I was a bit worried about the reliability, but if it lasts as long as Mezeire claims hourwise (cant remember the exact figure), it will outlast the stock LT1 pumps I have had. In my experience, the stock pumps have been very unrealiable (2 in 60k miles, both new GM pumps).
Old Jan 10, 2008 | 09:52 AM
vetteaddic's Avatar
vetteaddic
No ,and did notice some hp
Ive been running it for 3yrs. now and drive the car as much as possible.
Old Jan 10, 2008 | 05:29 PM
enkeivette's Avatar
enkeivette
You guys have settled my fear somewhat... I wouldn't be so afraid to put this on my 383 NA. But I'm adding a supercharger this week, which is why I'm still skeptical. Any boosted apps running an electric water pump on the street?
How big of an alternator should I run?
Old Jan 11, 2008 | 02:50 AM
Z-man's Avatar
Z-man
S/C here with electric fan, electric fuel pump, electric heated O2 sensor, electronic fuel injection, electric MSD ignition, electric headlights, electric windshield washer fluid squirter and electric water pump. I installed a CS144 (144A) alternator in case I put in electric power steering when I win the lottery.
Old Jan 11, 2008 | 07:39 AM
enkeivette's Avatar
enkeivette
Nice setup Z-Man. I didn't know that whipple made a SC for a SBC. Looks fun
Do you think I'd be ok running the stock alternator with just electric fans and an electric water pump?
Old Jan 11, 2008 | 11:39 AM
Mike Ward's Avatar
Mike Ward
Why the burning desire for electric fans and pump? Please don't fall for the old myth that it 'will free up some horsepower'.
Old Jan 11, 2008 | 12:42 PM
76 sting's Avatar
76 sting
It will to a point, but not enough to feel the difference.
And yes you will need to upgrade to a bigger alt. I have dual spals and and elec water pump. When running both fans I have issues when running 1 fan and elec pump I have no issues and that is with a brand new alt. I messed up and should have gone bigger on the alt.
To Electric Water Pump on the street?
Old Jan 11, 2008 | 02:49 PM
Mike Ward's Avatar
Mike Ward
Nope, sorry. The load that you take off the mechanically driven accessories is transferred on a 1:1 basis (at best) to the alternator.
It's very inefficient to turn mechanical energy into electrical, then turn it back into mechanical. That's what your doing by running electrical accessories from an alternator.
No free lunch.
Old Jan 11, 2008 | 03:36 PM
enkeivette's Avatar
enkeivette
Well I'm missing the special length water pump pulley that is supposed to come with my supercharger kit. The pulley itself is $70, and I also have to buy a long mechanical water pump to work with it. But if I went electric, I wouldn't have to buy the pulley or the new mechanical pump and the cost would be roughly the same... so that is my thought process.
I'm leaning towards the mechanical pump as of right now. If I went with the electric I'd have to fab up my own alternator bracket as mine bolts to the water pump (passenger side) and the electric pump has no provisions for the mount. And if it's slightly off, then I risk premature alternator bearing failure. I would also have to upgrade my alternator and/ or adapt the spare (4 wire plug) alternator that I have sitting in the garage. And right now I'm already overwhelmed with the supercharger install by itself.
So unless someone can prove to me that an electric pump will free up gobs of hp, I'm going to stick with the mechanical pump.
Mike Ward, not sure about electrical pumps saving power, but electric fans do. As they have the option of turning off, drawing no extra current. My fans are hardly running, as once I get moving the free air flow is enough to cool the radiator and the temp switch shuts off my fans. And although there is a clutch on a mechanical fan, there is still frictional loss even when it's slipping.
Old Jan 11, 2008 | 03:53 PM
enkeivette's Avatar
enkeivette
Originally Posted by Super Chevy
And the choice to run an electric water pump might save you some power, but it could cost you something more. You see nothing's free in the power-building world. What makes power for you in one area, can extract a price in another. While the power benefits of an electric water pump can hardly be denied, the costs of running one on the street can be harsh. Overheating would be your main cause for concern. That's because, while most stock and aftermarket belt-driven pumps can flow as much as 100 gallons of water per minute and racing pumps can flow even more, most electric pumps flow less than half that amount. It's a simple matter of physics and a giant paradox of performance. In order to flow enough water through the system, the pump requires a power source strong enough to move a large quantity of liquid. The gains from moving lots of water through the system are better cooling. The losses are measured in horsepower. An electric motor, on the other hand, does not cost horsepower to run, but instead it trades volume for power and cannot flow as much water. If you built an electric pump with a motor big enough to flow the huge volume of water equal to that of a belt-driven pump, it'd be so massive that you probably couldn't fit it under your hood. And the electrical power requirements for such a pump would make it impractical for use on any car.
So if electric motors can only flow half the coolant... I'm going to stick with a mechanical.
