demon carb choke
Old Jan 9, 2008 | 08:22 PM
dewease461's Avatar
dewease461
1st Gear
Default demon carb choke
Hello all, New member, 69 coupe ,L46, m21. 21st year Ive had this car.Need help with 650 demon carb choke install. Just cant see where the ends of the spring on the throttle shaft hook up... one end is hooked and the other straight on the spring . There is two end plates . the spring slips inside the u-bend of the 1st end plate then hooks to the 2nd end plate , these end plates slip over the throttle shaft. Restoring engine and components with some mods. Didnt think this would stump me but having mind melt.
