What Heads to Get?
Old Nov 28, 2001 | 07:15 PM
Blake-73's Avatar
Blake-73
Default What Heads to Get?
Ok, after careful discussion, it looks like I need to get new heads to lower
my CR down from 11-1 to something more tame so that I can eliminate detonation and open up the performance of my 383. So it is out with the
041 cast heads and in with something new. I would like some suggestions
on what heads are the best. Here is my setup:
383 stroker / Comp 270H cam / Flat top pistons on 6 inch rods / TH400
Dynomax headers / Edelbrock 600 cfm /
Any suggestions?
Blake-73
Old Nov 28, 2001 | 07:31 PM
nunus79's Avatar
nunus79
Default Re: What Heads to Get? (Blake-73)
Is it possible to get 11 to 1 w/flat tops?
You should first get a good idea of what your current comp ratio is before you start making new head decisions. Did you factor in valve relief CCs or deck/piston clearance CCs when you calculated comp ratio?
[Modified by nunus79, 2:43 PM 11/28/2001]
Old Nov 28, 2001 | 07:55 PM
tsw71's Avatar
tsw71
Since it's not my money we're talking about, why not get some new aluminum heads with a similar chamber size. This would allow you to maintain the higher compression, but give the same results as lowering the C/R by close to a full point. Also, what is the thickness of the heads gaskets you have now? If steel shim, you can lose close to a full point by going with .039" or .041" gaskets.
Old Nov 28, 2001 | 08:25 PM
Stingy74's Avatar
Stingy74
How much are you willing to spend? I'm not an AFR guy but I have heard good things about the Air Flow Research 190 heads. Good torque and power. If you want to get radical you can get into 200+cc intake runners to make some real high hp numbers at the cost of a bit of torque. The Brodix Track 1 has also made a good name for itself over the years. They make a new 222cc intake runner version. Flows over 300cfm of air right out of the box.
[Modified by Stingy74, 6:26 PM 11/28/2001]
Old Nov 28, 2001 | 09:37 PM
Paul 75 L82's Avatar
Paul 75 L82
When I get new heads I'm going for the Trick Flow.
To What Heads to Get?
