TPI 7727 computer install
Old Jan 12, 2008 | 02:21 PM
TPI BOY's Avatar
TPI BOY
Default TPI 7727 computer install
For those who have installed a tpi non maf using map using
7727 computer where did you install the computer
under the hood
Old Jan 12, 2008 | 02:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I plan to install mine to the passenger-side inner fender behind the A/C accumulator/drier. Easy access through the splash shield at the bottom of the fender.
Old Jan 12, 2008 | 03:12 PM
Rotonda's Avatar
Rotonda
I installed mine on the left side on the rear of the fender well in place of the charcoal canister. It is slightly raised and gets airflow on all sides from air exiting through the fender vents. It is JUST visible from the outside, if you look into the vent. It is servicable from underneath by removing the splash shield. My Crane spark box is mounted in a similar position on the fight side, and the rev limiter can be adjusted through the vent.
Old Jan 12, 2008 | 04:36 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
under the hood
Looks like you got good answers to your question.
Do not mean to hijack the thread but those of you that have done a TPI install can answer a very important question concerning the installation. Who did your prom burning for you to eliminate VATS etc? Were you satisfied with the work the programmer did?
Old Jan 12, 2008 | 04:38 PM
Artsvette73's Avatar
Artsvette73
I plan on mounting at the left side fender well. I have the holley stealth ram. Not to change the subject but what did you guys do for the harness? I have a corvette tpi harness for the 7727 it would need to be made longer. I was looking at Jims Performance
Old Jan 12, 2008 | 04:55 PM
Red 71's Avatar
Red 71
Painless makes one with extra long computer cables (+48")
Old Jan 12, 2008 | 05:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Got my own eprom burner and adapters that plug in between the factory memcal and the board so that it's easy to change chips.
Old Jan 12, 2008 | 05:35 PM
TPI BOY's Avatar
TPI BOY
Can you tell me more about the adapters and how that works i have my
burner but a pain to keep changing chips
Old Jan 12, 2008 | 07:54 PM
KENS80V's Avatar
KENS80V
As far as I know the Painless harness is not for the 7727 ECM. The connectors at the ECM are different. www.pcmforless.com burned my chip and is highly recommended on the C4 section of this forum.
Old Jan 12, 2008 | 10:36 PM
Red 71's Avatar
Red 71
The Painless 60203 harness is listed for the 90-92 Camaro and Corvette MAP systems so I would assume the 7727 (vette)and the 7730(Camaro) ECM connectors would be the same but have not compared them side by side so I do not know for sure. With the longer cables you could install the 7730 ECM inside if you wanted to. Of course with all the room under our dashes that may be a little tight.
Old Jan 12, 2008 | 11:21 PM
1982CorvetteDude's Avatar
1982CorvetteDude
www.tpiparts.net
http://tpiparts.net/inc/sdetail/657
http://tpiparts.net/82_92_wiring
He does an awsome job, I just called him friday and ordered a new chip to add EGR (I had it deleted off my old one). He only charged me $30 since I had the adapter from the first purchase.
I built 90% of my system from there, they do harness modifications too
Old Jan 12, 2008 | 11:53 PM
77 vette's Avatar
77 vette
Great timing
I was going to locate my 7727 on the passinger side inner fender, I do not have AC so it's wide open back there for easy access to the ECM.
Old Jan 13, 2008 | 12:43 AM
comp's Avatar
comp
Old Jan 13, 2008 | 02:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Here is a very old thread on the subject from the GMECM forum, but I don't know how long it's going to be around: http://gmecm.mine.nu/viewtopic.php?t=18
Some pictures:
I don't have any contact info for him beyond the PM feature there. I don't know if he's making them anymore or not.
Old Jan 13, 2008 | 02:37 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ah ha! Found a place to order them: http://www.moates.net/product_info.p...products_id=32
And a good overview of the installation: http://www.moates.net/documentation....mentation_id=9
Not exactly identical, but functionally the same.
Old Jan 13, 2008 | 07:52 AM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
I use TPIS up in Minnesota. Their harnesses are awesome and they do all the chip programming. That's Myron Cotrells company and I am extremely satisfied with their work. They are pretty close to Rippie.
Old Jan 13, 2008 | 09:09 AM
Brandywine's Avatar
Brandywine
Originally Posted by 1982CorvetteDude
www.tpiparts.net
There's Jims Performance also...
http://jimsperformance.com/
To TPI 7727 computer install
Old Jan 13, 2008 | 09:14 AM
1982CorvetteDude
I bought my cold start delete plug kit from him and was disatisfied with the way the rear rail plug worked. I ended up using the runner plug that came with the kit and bought a threaded rear plug from street and performance.
His prices look good though
Old Jan 13, 2008 | 01:31 PM
TPI BOY's Avatar
TPI BOY
www.tpiparts.net
You guys need to learn to program your
own chips and you can change anything you want
at anytime the new software they have out now
really helps
Old Jan 13, 2008 | 01:37 PM
TPI BOY's Avatar
TPI BOY
Yes, I should have thought about him, he has alot of
good stuff that really works well
