How Much Power?
Old Jan 12, 2008 | 06:43 PM
curtis75's Avatar
curtis75
Default How Much Power?
I have a 350 that I spun a bearing in on the dyno. So I tore it all apart and was told that the block was ok but the crank should only be used as a paper weight. I decided to go with an Eagle internally balanced 383 kit with 5.7in rods and 10.4:1 cr. I have a set of Vortec 062 heads with roller rockers and roller hydraulic lifters set up to work with my cam which has 510 lift and 230 duration at .050. How much power do you think it will make
Old Jan 12, 2008 | 08:16 PM
Gordonm's Avatar
Gordonm
431 HP. My guess.
Old Jan 12, 2008 | 08:18 PM
strokervette's Avatar
strokervette
418hp And that's my final answer.
Old Jan 13, 2008 | 10:10 AM
Mike Ward's Avatar
Mike Ward
Zero unless you add an intake and exhaust system.
Old Jan 13, 2008 | 10:31 AM
Capella's Avatar
Capella
Compression may be a bit much with those heads on pump gas - hard to put in much timing without detonation when much over 9:1.
Old Jan 13, 2008 | 10:49 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I'm not guessing unless you are putting it on an engine dyno ?
Old Jan 13, 2008 | 10:52 AM
my mach 5's Avatar
my mach 5
Old Jan 13, 2008 | 11:22 AM
curtis75's Avatar
curtis75
I have a performer RPM intake with a 650 Holley right now but I might swap the carb out for somethig bigger. I have block hugger headers and stock 69 side exhaust. I havent heard of an engine dyno anywhere around me but I do plan to put it on a wheel dyno once I get it back in the car.
Old Jan 13, 2008 | 03:59 PM
jackson's Avatar
jackson
Originally Posted by curtis75
I have a 350 that I spun a bearing in on the dyno. lift and 230 duration at .050. How much power do you think it will make
This a good example where stating your approximate geographic location might get you a hand up.
Lord knows if it spun one on chassis dyno already ... that oughta be some incentive to find an engine dyno before you install another motor ... fill out your profile w/ approx geog location & maybe someone can point you to nearest one.
If I were spending $ on internal flattop 383 kit for a roller cam motor ... I'd choose 6" rods & pistons to match.
Old Jan 13, 2008 | 06:37 PM
curtis75's Avatar
curtis75
why would an engine dyno make a difference over a wheel dyno as far as stress on the engine goes. As far as I'm concerned a wheel dyno is better because it tells you how much power you make actually have at the wheels and not at the flywheel which could be 15-20% less. The reason it spun a bearing was because it was a tired motor that I planned on rebuilding but wanted to get a baseline first, the other bearings, that didnt spin, were pretty worn out (could see the copper)
Old Jan 13, 2008 | 06:43 PM
MotorHead's Avatar
MotorHead
320 RWHP
Old Jan 13, 2008 | 10:29 PM
jackson's Avatar
jackson
I suggested an engine dyno because ... if you have a failure it's much easier to fix ... easier than if the motor's in a car. You might also consider that most professional performance quotes are from engine dyno runs ... easier to compare apples to apples. When you said you spun a bearing on a dyno ... I didn't realize until your last post that you were dynoing a tired motor that needed help.
Old Jan 14, 2008 | 12:03 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
With a decent exhaust and good intake, I'd estimate about 250 RWHP with TH400 and about 290 RWHP with stick shift.
To How Much Power?
