Hi,
I've just replaced the solenoid on my starter and taken out the old washers that were being used as shims to mount the starter to the block.
I've put in four shims and that is nowhere near enough.
So the question is:
Is it a problem if I put in 6 shims to set up the correct engagement?
(Not is there a problem - but is it OK to use large numbers of shims)
I guess since it is metal to metal it is not a problem - just not desirable, thoughts please.......
What was in there before I hear you ask.
a 2mm washer on one side and a 1mm washer on the other - so it was canted over very slightly - thus giving the clearance needed.
I want to try and set it up flat and with the correct clearance.
Jeremy.
Reason: addition
I was always told the best thing to do is put exactly in what you took off and you will have no problems. 4 full shims seems like a lot to me and still be to close to the flywheel. But I am not an expert I bought a 75 with out a starter and have been having problems with getting a new one working right. As of right now I have no shims at all on mine. I start it up one time it engages perfectly fine and smooth I go to start it up again a few minutes later and it makes a horrible noise. I get the same thing pretty much with any amount of shims so I am not sure what to do with it.
How are you getting the bendex gear on the starter out to check the clearance?
When shimming a starter, remove the solenoid so you can use your fingers to engage the starter and see how much clearance you have between the teeth of the flywheel and the starter. You can use a .030piece of wire or a thick paper clip and see if it fits between the teeth.
You should only need to add 1-3 shims at the most, if any. It sure sounds like the wrong flywheel or starter combination there if Bubba had washers as shims.
Dante7 - I've always been told to check the clearance on three or four positions. You can get a situation where the clearance is correct for one part of the flex plate but is too tight on another. Recommendation is that you set up the shims for the tightest part.
It could be that this is your problem, or that you have some worn or damaged teeth on one small part of the flexplate. Try winding round from the balancer bolt or with a gear wrench whilst watching for damaged teeth. (Might need a second pair of hands for this).
Back to my problem:
It is a reconditioned starter and it doesn't fit as good as it ought to.
The question is: is using 5 or 6 shims a problem.
(I know it's not ideal or normal) - but is there a problem doing this if it gets the right result.?
(I am doing this manually with no solenoid as has been suggested).
Thanks........
Jeremy.
Reason: addition
Hi J,
Had a similar problem with mine had to use a lot of shims to get it right and it was fine for about three months then the drive gear shattered. Are your bolt holes parrallel or offset, if they're offset as you shim out it throws the drive gear out of line with the ring gear. which i only realised when it was too late.
P.s. did leave a reply to your other question about the th200r4 did you see it.
Peter
The use of shims is to get the drive away from the ring gear. And most of the time shims are not needed contrary to some opinions on these forums which are normally wrong. I would recommend to install the starter without the shims and check the clearance. You may be surprised and have a quieter engagement between the drive and ring gear. .....
