Rearend Compatability
Old Jan 14, 2008 | 09:40 AM
ARCH's Avatar
ARCH
Default Rearend Compatability
I am looking to swap out my rear end on the 68 to 4:11s. Just have a couple of questions. Are all 63 to 79 rearend compatable? If it has HD side yokes, will there need to be a corresponding upgrade to the halfshafts?
Old Jan 15, 2008 | 12:49 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i am by no means an authority on the iron 36's but as i understand it they are all interchangable physically, as far as in the framerails. the only issue, as you mentioned, should be the half shaft yokes. i don't remember the exact numbers but i think the HD yokes were 1/2" wider than the standard yokes.
if you're going to 4.11 though, it probably wouldn't be a bad idea to upgrade the half shafts and spindle yokes too.
Old Jan 15, 2008 | 04:36 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think (though I'm by no means positive) that the u-joints are the same, the HD yokes are just heavier and use caps rather than the strap bolts.
Old Jan 15, 2008 | 08:22 AM
GTR1999's Avatar
GTR1999
Any 63-79 iron unit will fit your car. There are some differences internally and I would look for a 71-79. Now if you're planning on just bolting in a used 411 diff be prepared for possible problems. Check it out good before installing, most used diff's I see need attention and 411 units were usually pounded on. If you go with an early one,63-68 check the posi case very carefully.
Be aware the posi cases are different between a 3series gear(273-370) and the 4 series (411 456 488)
The HD yokes just have the caps that's all.The yoke are the same other then the holes to secure the joint. Your 1/2 shafts are fine to use, maybe upgrade to a Spicer solid joint.
If you need more info PM me and I'll link you to everything you need to know about a vette diff.
Old Jan 15, 2008 | 08:28 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Good information right there. Check the posi case carefully, and you may even want to update it if you plan on pounding on it. As Gary said, you'll need a different posi case for the 411 if you're running a smaller gear in it currently. The side-to-side position of the face that the ring gear mounts to is different between the 3s & 4s.
Old Jan 15, 2008 | 09:32 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
One thing not mentioned. The pinion yoke went to a larger size in 1969 or 70, can't remember which year but the u-joint is wider on the newer pinion yokes than the older pinion yokes.
Old Jan 15, 2008 | 10:26 AM
GTR1999's Avatar
GTR1999
Very good point. The early units will have the small yoke then for a couple of years they were split between the small and large and then finally the large. Also the yoke OD is very often overlooked in a rebuild as the speedy sleeves run about $30 and a good used yoke about $75-$100.
Old Jan 17, 2008 | 02:04 PM
ARCH's Avatar
ARCH
Concerning the pinion yoke differnces would there be compatability issues with putting a 77 rear in my 68, or would I be able to just use a smaller yoke with the 77 rear.
Old Jan 17, 2008 | 04:49 PM
GTR1999's Avatar
GTR1999
You can swap the yokes the spline is the same. You want to follow the correct preoad procedure if you do and use #271 loctite on the threads and # 2 on the splines. Might as well replace the pinion seal.
Old Jan 17, 2008 | 06:55 PM
SpE3dF0x's Avatar
SpE3dF0x
Before I start dropping horses on my 76...I keep hearing that my reaerend won't hold...what do HD rearend have over OEM?
To Rearend Compatability
