How do you Disconect the handbrake cable?
Old Jan 14, 2008 | 04:08 PM
la80vette's Avatar
la80vette
Default How do you Disconect the handbrake cable?
Prepping for a body lift on my 80' and I need some advice on how to remove the ebrake cable (safely).
Thanks,
Stephen
Old Jan 14, 2008 | 04:29 PM
coinwasher's Avatar
coinwasher
The cable that comes up to the U shaped piece from the rear wheels can be unhooked right at the spring underneath the car. You need to be under there anyway to unbolt the seat belt safety loop at the back of the drive shaft tunnel. Good luck!
Old Jan 14, 2008 | 04:35 PM
la80vette's Avatar
la80vette
Thanks very much. I'm gonna go do that right now.
Old Jan 14, 2008 | 05:19 PM
coinwasher's Avatar
coinwasher
Here is a picture of the area
Old Jan 14, 2008 | 08:07 PM
coinwasher's Avatar
coinwasher
Oh yea, after you loosen it all up at the spring, you need to remove the plastic pulley that is bolted to the frame and leave the cable that is hanging out of the body clear for your pull.
Old Jan 15, 2008 | 10:23 AM
la80vette's Avatar
la80vette
Thanks I got it. Although I ended up pulling the whole handbrake assembly out with the cable attached.
By the way your car looks awesome. I hope my chassis will be as nice.
Stephen
To How do you Disconect the handbrake cable?
