Frame paint question while changing body mounts
I figured while i had one side of the car slightly lifted I would do as much preventative maintenance as possible such as wirewheeling and putting paint on the framne while it was up. But to do this would mean keeping that side of the body lifted for multiple days. From all the searches i could think of I couldnt find out whether it was ok to leave one side lifted for multiple days on jacks with 2X4's on one side or if that would cause serious damage and the body mounts should just be changed and set back down.
Also, all the walkthroughs i could find said to disconnect the steering column at the rag joint and lift the column or just disconnect the steering box from the frame. Does anyone has a photo of where to disconnect it properly or have advice on which is the best way?
Sorry about the stupid questions. Probably something I shouldn't be attempting but it is a learning experience for me and I insist on doing it myself. Thanks for any help or advice.
As far as removing the steering coupler, the "Search" function is your friend. Lots of different threads on this, here is just one example.
http://forums.corvetteforum.com/show...eering+coupler
Good luck with the job.
I did go out and buy 6 extra jack stands for this project, I am already use 4 jack stands on the frame and one on the back end, and one on the radiator core support. I figured once I jacked the body up a few inches on one side I would use the spare six to support the body from front the back to give it at much support as I can. Glad to hear that a couple days lifted shouldn't hurt it.
Thank you once again for the help and sorry I forgot to mention in the original post that it was a 78.
