DIY front coilovers.
Old Jan 18, 2008 | 09:15 AM
dk-corvette's Avatar
dk-corvette
Default DIY front coilovers.
Hi Corvette-friends,
I'm considering to make a front-end coilover convertion with QA1's on my car, like "SCHMUCKER" did some years ago. You can see one of his post about the subject here:
http://forums.corvetteforum.com/show...ight=coilovers
I have tried to contact "SCHMUCKER" to hear what QA1 dampers he used in his project, but unfortunatly he is not active on the forum anymore.
Looking in the arcive I found out that he was using some 10" long springs in the front and on the rear he used QA1 #DR4855B dampers.
Does any of you know if he used the same dampers on the front?
Best regards, DK.
Old Jan 18, 2008 | 02:38 PM
72LS1Vette's Avatar
72LS1Vette
Check out item HAL-GMP4350-1 at summitracing.com
Rick B.
Old Jan 18, 2008 | 05:54 PM
dk-corvette
Hi Rick B,
Thanks for your input. I have also been considering the semi-coil-over you are suggestion but I would really prefer to go for a full solution with the benefits it gives.
If money was no problem I would go for the Van Steel solution but I can’t seem to find the 2K for it. With a DIY solution I hope I can make my own for less than 1/3 of the price.
I think that SCHMUSKER were using the same dampers front and rear but I'm not sure. I'm really hoping some of you can help me out here.
Thanks and best regards, DK.
Old Jan 18, 2008 | 06:11 PM
dannyman's Avatar
dannyman
Hope this works for you:
Failing this you could also go to the DC (the dark side) and put out a shout for Smuck. He regularly got involved with the infamous dozen.
Old Jan 18, 2008 | 06:26 PM
dk-corvette
Hi Danymann,
Thanks for your input. Unfortunatly your link is not working on my computer. Will you please try and look into it and maybe put on a new link?
Thanks, DK.
Old Jan 18, 2008 | 07:06 PM
dannyman's Avatar
dannyman
Originally Posted by dk-corvette
Hi Danymann,
Thanks, DK.
Works fine on mine. It is 8-9 threads started by Smucker all related to coil-over. I can't explain why the link works on mine and not yours.
You could also try to cut and paste the link to your browser.
Old Jan 19, 2008 | 10:09 AM
dk-corvette
Am I the only one where this link is not working?
I also tried to find SCHMUCKER on DC, but unfortunatly without success.
HELP-HELP / DK
Old Jan 19, 2008 | 12:19 PM
dannyman's Avatar
dannyman
OK. Try this!
Pull up your link to Smucker.
Left click - his name (Smucker)
Left click - View Public Profile
Left click - Find all threads started by Smucker
Search comes up empty - that's OK
Type in search keyword - (coil-over)
Select - Archives
Select - C3 Corvette 1968-1982
Select - Search Now
This will give you a list of his threads.
Old Jan 19, 2008 | 06:26 PM
dk-corvette
Thanks Dannyman,
I went through most of Smuckers threads before I started this one. I can't find any place where he mentions the part# on the front QA1.
I think it is the same as the ones he used on the back but it would be nice to know for sure before I make the order at Summit
Maybe somebody else can help me out?
To DIY front coilovers.
