Harnesses and the law
Old Jan 19, 2008 | 12:19 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Harnesses and the law
So my seatbelt supports are pretty much unsalvegable at this point. There is a support in the transmission tunnel that appears to be unreplacable and it has disintegrated on me. So my question is. Can I run a shark bar and harness get up legally in lieu of my seatbelts. It would appear to be much safer to me.
Old Jan 19, 2008 | 12:47 PM
Gordonm's Avatar
Gordonm
I would think they could look at it and see that it is much better than just the lap belts that came in the car. I'll be running a 5 point harness in mine.
Old Jan 19, 2008 | 02:34 PM
Guru_4_hire
Cruise-In V Veteran
I talked to the inspector and it should be alright.
Provided that we reuse stock seatbelt points, and everything is securly mounted.
Old Jan 19, 2008 | 04:14 PM
my74ls4's Avatar
my74ls4
Your seatbelt mounting point in the transmission tunnel can be replaced. I believe it is just rivited in. I could take a look at one I have from an old parts car.
To Harnesses and the law
