Help
Old Jan 21, 2008 | 11:26 AM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
Default Help
Short story long.
Drive to Bisbee Saturday, everything's fine.
Sunday, go to move her out to paint the garage, everything's fine.
Go to move her back into the driveway, she starts up fine, but then starts shaking like nobody's business, then dies, can't get her re-started.
Thinking fuel filter or timing. She cranks over, just no combustion happening, so either no fuel, or no spark...can't get her to turn over to see if she still shakes like Charro.
Old Jan 21, 2008 | 11:32 AM
Durango_Boy's Avatar
Durango_Boy
After checking to make sure you have fuel and spark, look for a vacuum leak. They can cause VERY rough idles at low RPM.
Old Jan 21, 2008 | 11:56 AM
DVNTST8's Avatar
DVNTST8
St. Jude Donor '09
Thanks DB.
It IS a she...I got her started, so I'll be checking for vacuum leaks as soon as I get my garage painted.
Going to take all the emissions junk off anyway. Can do that here, as long as I register her as a collectible.
Old Jan 21, 2008 | 01:17 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Backing her in and out of the garage without ever getting the engine warmed up will foul out a set of plugs very quickly. If you are doing this, you might want to check the plugs.
To Help
