Oil Pressure switch, and coolant temp senders?
Old 01-21-2008, 01:12 PM
ZD75blue
ZD75blue's Avatar
Default Oil Pressure switch, and coolant temp senders?
Hi guys...
Putting my 1975 L48 engine back together after a few years, its been in pieces for a few years now... I've forgotten where the sender goes for the oil pressure, and where the coolant temp sender goes.
Thanks guys.
Old 01-21-2008, 01:27 PM
Durango_Boy
Durango_Boy's Avatar
Originally Posted by ZD75blue
Hi guys...
Thanks guys.
The oil pressure sender goes just up and over from the oil filter. The temperature sender goes in the driver's side head.
SIXFOOTER
Support Corvetteforum!
SIXFOOTER's Avatar
Oil Pressure is right next to the distributor, Water Temp is drivers side head between 1 & 3, Oil temp in the block just above the oil filter
To Oil Pressure switch, and coolant temp senders?
Quick Reply: Oil Pressure switch, and coolant temp senders?
