c3 audio setup - pics/inspiration
Old Jan 23, 2008 | 08:38 AM
ace_cobra's Avatar
ace_cobra
Default c3 audio setup - pics/inspiration
im currently restoring the interior of my 70 vette and i need some advise on the rear speakers. The car ha d a removable rear window so if i were to mount speakers in the back i would still need some access to the window storage. Has anyone put speakers in the back with the removable window storage functional? This is what i have now, just sony x-plod 5 1/4's and the Corvette USA 3 stereo. Also, will i need an amp or no, audio systems are not my forte!
Old Jan 23, 2008 | 10:45 AM
Disco_Mike's Avatar
Disco_Mike
my dad replaced the factory radio with an analog cassette player in the early 80's.
Old Jan 23, 2008 | 01:14 PM
another-user's Avatar
another-user
i just made some new tray lids and put 2 6x9s in there.
Old Jan 23, 2008 | 02:04 PM
vettfixr's Avatar
vettfixr
I don't have a removable window on my 74 but here's a link to my stereo post. It may give you some ideas/inspiration.
http://forums.corvetteforum.com/show....php?t=1049772
Old Jan 23, 2008 | 02:08 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I have no removable window, but do have speakers back there:
Left side 6x9
Right Side 6x9
Storage Area
Power Amp behind seat:
The rear speakers are mounted in carpeted plywood panels that are cut to fit tightly inside those rear recesses of the wheel well. They don't take up ANY CARGO AREA space at all.
Old Jan 24, 2008 | 08:16 AM
ace_cobra's Avatar
ace_cobra
how is the sound with 2 speakers in the front and 2 in the rear. I am worried that with the small cabin it will sound to close together.
Old Jan 24, 2008 | 10:42 AM
SuprJames's Avatar
SuprJames
Does the amp get enough air? Looks like cooling would be a problem with the seat pressed right up against it, but I'm definitely no expert. Love how clean the installation is though.
Old Jan 24, 2008 | 05:20 PM
ajrothm's Avatar
ajrothm
Here is how I did mine, no problem with getting the t-tops in the rear or with the window tray opening.
Old Jan 24, 2008 | 05:40 PM
Stroker-427's Avatar
Stroker-427
....Viper loudspeakers in a Corvette!!!!!
Old Jan 24, 2008 | 06:04 PM
mateo270's Avatar
mateo270
No room for storage, but it bumps. Two 8" subs and two 6x9's.
Old Jan 24, 2008 | 06:20 PM
onaqwst's Avatar
onaqwst
2 jl10w6v2 in the rear corners...fiberglass pods
2600 and 6600 ppi amps
6/4/tweet components
2 caps...
b
Old Jan 24, 2008 | 06:57 PM
another-user
this is what i did with mine last year, along with 4x6s in the dash. i was quite happy with the way it sounded
i didnt have time to clean up all the old crap that was under the carpet last year, but ive pulled everything out this year and im going for a cleaner look. i also decided to pick up some quality parts this time around, rather then the cheap pioneers.
the wiring is Knukonceptz 4 gauge Kolossus Fleks and Krystal Kable RCAs. beats the hell out of the 10 dollar complete amp wiring kit i bought off ebay for the original install.
Old Jan 24, 2008 | 11:58 PM
ace_cobra's Avatar
ace_cobra
ok so again, are 2 speakers in front and 2 in the rear too much or shud i go with just the 2 in the front and maybe a sub? Also if i go for 2 in the rear will i need an amp?
Old Jan 25, 2008 | 12:08 AM
another-user
i wouldnt run anything off the head unit. amp everything.
ive heard alot of people say to put everything up front and nothing in the back. personally, i liked having sound coming from both infront and behind me.
Old Jan 25, 2008 | 08:34 AM
mateo270's Avatar
mateo270
If I were to do mine again I would go with SanDiegoPaul's 6x9 setup and get ajroth's sub. Then you have sound in front and back with some thump. Put your amp in the storage compartment. Just my opinion...
Old Jan 26, 2008 | 08:52 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Left side 6x9
Right Side 6x9
Storage Area
Hey SanDiegoPaul, that is a real sweet set up!
Old Jan 26, 2008 | 10:07 PM
A C's Avatar
A C
Cruise-In II Veteran
After installing components in the front and only one sub in the back, I have found the sound to be great.The cabin is really small, and I don't miss full range speakers in the back at all. Here's my rear setup. T-tops fit just fine.
To c3 audio setup - pics/inspiration
Old Jan 26, 2008 | 10:34 PM
BigBlockTank's Avatar
BigBlockTank
I used a thin line (3" mounting depth) Clarion sub in a .65 cubic foot sealed enclosure with Polk Audio DB6500 6.5's in the kick panels. I put the crossovers behind the quarter panels, just behind the seats along with the seperate tweeters there as well (tweeters are mounted below head/ear level). The amp is mounted all the way back on the back wall. The sub is on the other side of the back wall. They take up very little space. When I turned on this system for the first time, I wanted to turn around and offer the guitar player a beer. It is very clean, rich and booms when I crank it up. I couldn't be happier.
Old Jan 27, 2008 | 08:25 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Nice Set Up on the rear speakers
Did you customize the rear boxes and speaker set up or were you able to find these pre-made. This is exactly the look I was seeking.
Thanks for any additional information.
David
Old Jan 27, 2008 | 11:00 AM
SanDiegoPaul
Mine sounds awesome. the amp is 250W.
