lets go cam hunting
Good Luck with the new project.
That cam that was recommended to you is just about what I had in my head when I read your post.
http://store.summitracing.com/partde...5&autoview=sku
Groove your lifter bore for optimum performance.
These COMP Cams lifter bore grooving tools are designed to groove the lifter bore to ensure that pressure-fed oil is directly injected into the contact area between the lifter and the camshaft. Increased oiling will significantly decrease wear on the camshaft and lifters, and decreases the risk of premature failure during the break in process. They include a carbide bit cutter, grooving tool, and handle. Replacement carbide bits are available separately.
and for the hydraulic roller retro-fit use kit # CL12-433-8 http://www.compcams.com/Technical/Se...umber=12-433-8
I'll probably spend the money and go for the retro-fit, I cheaped out once and paying for it now, lol. I told him it was a street legal car but will be mainly used on the strip.
Here's my motor build.
1974 350 L-48 engine
Bored .030 - making it 355
scat crank and rods - stock sizes
10 1/2 : 1 compression pistons
Comps cams 280H - Cam Style: Hydraulic flat tappet
- Basic Operating RPM Range: 2,000-6,000
- Intake Duration at 050 inch Lift: 230
- Exhaust Duration at 050 inch Lift: 230
- Duration at 050 inch Lift: 230 int./230 exh.
- Advertised Intake Duration: 280
- Advertised Exhaust Duration: 280
- Advertised Duration: 280 int./280 exh.
- Intake Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
- Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
- Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.480exh. lift
- Lobe Separation (degrees): 110
Dart Iron Eagle Heads - 65cc
- 200cc runners
- 2.02 valves
1.6:1 pro comp aluminum full roller rockers - brings lift up to .512
pro comp stub girdles
Holley street Dominator intake
Holley 670 Street Avenger Carb
HEI Distributor
shorty header going into 2 1/2 exhaust to sidepies
4-speed tranny
3.36 rear gears
Last edited by qwik-tripp; Jan 25, 2008 at 07:06 PM. Reason: spell like a 1st grader
