Hydroboost line help please
Old Jan 25, 2008 | 01:10 AM
Bee Jay's Avatar
Bee Jay
Default Hydroboost line help please
I'm currently installing a Holley 950 TBI fuel injection, and there is no vacuum outlet for power brakes on the throttle body. No biggie. I've got this Hydroboost unit on the shelf that I've been waiting for the right time to install. Now is the time. I need help on the lines. I've read several times that there are factory lines available over the counter, but I need part numbers. I need two lines:
One a 22" hose with a 3/8 male flare on one end, and a 18mm x 1.5 male, o-ring compression on the other end. This line goes from the power steering pump to the Hydroboost "in" line.
Another hose 35" long with a 16mm x1.5 male, o-ring compression on one end, and I'm not sure what size goes on the other end, but it goes from the Hydroboost "out" line to my 79 power steering assist control vlave unit "in" line.
If someone could help me with part numbers or vehicle models to buy these two lines, I would really appreciate it. It's gotta be cheaper than having the lines built. I have all the part #s to do braided hose, but this is a "while I'm in there" project, and I'm on a budget right now. Maybe I'll install braided hoses later.
Thanks in advance.
Bee Jay
Old Jan 25, 2008 | 03:03 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Someone posted a diagram with the Summit part numbers to build the lines out of Aeroquip parts. I think it cost me around $150.
Old Jan 25, 2008 | 08:23 AM
Durango_Boy's Avatar
Durango_Boy
There is one part you won't find a number for, as there is only one place to get it in order to properly make your lines. It's the male to male adapter that goes into the valve, and converts the 7/16-24 bung to 6AN, which is what fitting your hose should end up with. You can very easily find a 7/16-24 to male 4AN but not 6AN unless you find an obscure heavy truck or aircraft parts dealer that has one. They are not common for automotive use.
Now, you can use the 7/16-24 to male 4AN fitting, and adapt it to 6AN to match the line, but there is very limited space between the valve and the frame, and if it's not done correctly the fitting on the end of the hose will contact the frame.
However, if you can find a fitting that is 7/16-24, that goes into the valve, that successfully mates with your tubing design, then go for it, just make sure it's 90 degrees.
Old Jan 25, 2008 | 12:09 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Which fitting is that? I didn't have any trouble getting the right fittings to make my lines, but I just used rubber fuel hose and barbed for the low-pressure returns.
Old Jan 25, 2008 | 12:12 PM
Durango_Boy
This is the hard to find fitting. I snapped the pic before I installed my kit from Hydratech in the car.
It's a 7/16" - 24 to male 6AN
Old Jan 25, 2008 | 03:37 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
there has been a few members here use the factory hoses and take them to the local hydraulic hoses and fitting shop to have them moded to work, I think YellowSB (Chris I think is his name) had his done this way, I think I recall mrvette also had his done this way to, very cheap if I remembe correctly. I tried Hydratech braking back when I installed mine but they would not sell just the line set and would not sell the fittings either. Today they sell everthing you need to build the line set, you may call them and ask if they sell the complete line set to fit.
Neal
Old Jan 25, 2008 | 03:39 PM
Durango_Boy
Neal
They will sell the whole kit as a turn key affair. I was the first person they sold it to. It's about $250 plus shipping for their kit. The 7/16-24 adapter is the only piece of that line kit that they will not sell individually, simply because they know without it they stand a better chance of selling the whole kit instead of a $25 fitting.
Old Jan 25, 2008 | 03:57 PM
mrvette's Avatar
mrvette
Well, not to ME....i'ts really simple to combine these lines as needed, just get the correct compression unions from Lowes Depot, and use them correctly....cut the lines with a tubing cutter, it's tough being steel, but doo able....
I have not spent a dime on hoses, and I have switched from '88 vette serp drive/ps pump setup in a total stock '72 vette, then went to the rack ala Steeroids in about '02 , then went to HB brakes ~2 years ago....never spent a dime on lines...all junkyard engineered....used a total of TWO brass compression couplings....one straight off the pump, been waiting for it to fail...but it's been some 6 years now, and not one leak....3/8 union compression...brass with rings just like a plumber would use....same for the output to rack off the HB unit...
Years ago, I DID have custom AIR CONDITIONING HOSES made up locally....but never hydraulic, I could, but these work fine....
Old Jan 25, 2008 | 04:05 PM
Durango_Boy
I remember I told someone once that they could make it them self or have a shop make the end of the line properly using the end of the stock line, and guess who jumped all over me like it was blasphemy? TT himself. He went on and on about how the proper flaring kit was too expensive for a normal guy to have in his shop despite the fact that I myself have one.
Since then I don't even bother with that anymore. Buy them for $250, or have a hydraulic shop make them for you for cheap.
Old Jan 25, 2008 | 04:21 PM
livelotus's Avatar
livelotus
Greetings,
Maybe this might help, when I'm trying to buy the odd type fittings I usually start with these places:
http://www.batinc.net/plumbing.htm
http://www.aircraftspruce.com/
http://www.pegasusautoracing.com
http://www.cantonracingproducts.com/
http://www.joesracing.com/catalog/
Good luck!
Old Jan 25, 2008 | 06:18 PM
chris75stingray's Avatar
chris75stingray
here's what i did:
Part Number QTY
AER-FBM1122 3 ( 90* 6AN fitting)
AER-FBM1144 1 (3/8"male flare to 6AN (90*))
AER-FBM2608 1 (16mm to 6AN )
AER-FBM2609 1 (18m to 6AN )
AER-FBM2930 1 (7/16"-24 to 4AN )
AER-FCC0606 1 (6 ft of high pressure braided line)
EAR-991906ERL 1 (4AN to 6AN adapter)
EAR-915104ERL 1 (4AN coupling)
EAR-921104ERL 2 ( 90* 4AN coupler)
POWER STEERING PUMP --fbm1144----fcc0606----fbm1122----fbm2609---HYDROBOOST---fbm2608---fbm1122---fcc0606---fbm1122---991906erl---915104erl---921104ERL---921104ERL---fbm2930---POWER STEERING CONTROL VALVE
it might look like alot coming off of the control valve but when its on the car it looks fine
Old Jan 25, 2008 | 07:19 PM
MakoVette's Avatar
MakoVette
Russel #697100 7/16-24 to #6 an
http://store.summitracing.com/egnsea...s=false&N=+115
Old Jan 25, 2008 | 07:22 PM
Durango_Boy
Originally Posted by MakoVette
Have you ordered one of those before? I'd love to see a pic.
Old Jan 25, 2008 | 07:26 PM
MakoVette's Avatar
MakoVette
Old Jan 25, 2008 | 07:28 PM
MakoVette's Avatar
MakoVette
Its on page 30 of russels 06-07 catalog
Old Jan 25, 2008 | 07:34 PM
Durango_Boy
Comparing they seem close enough, but I seem to recall someone ordering one and it didn't fit. I'll have to order one and test it and play with it. If it's for real then thank god someone out there sells one. It'll make making lines for Hydros a LOT easier.
Old Jan 25, 2008 | 08:13 PM
MakoVette's Avatar
MakoVette
Good Luck, let me know if it works
To Hydroboost line help please
Old Feb 6, 2008 | 06:36 AM
jerome1979's Avatar
jerome1979
Old Feb 6, 2008 | 02:11 PM
Durango_Boy
Here's the line fitting information, in all Russel Performance fittings from Summit.
From Pump To Hydro:
90 Degree 6AN to 3/8" - AER-FBM1343 - $23.95 (Red)
22" 6AN Braided Hose - AER-FCC0606 - $33.95
90 Degree 6AN Hose End - AER-FBM1122 - $18.99 x3
Male 6AN to 18mm O-ring Coupling - AER-FBM2609 - $13.95
From Hydro To Steering Valve:
6AN to 16mm O-ring Coupling - AER-FBM2608 - $13.95
90 Degree 6AN Hose End - See Above.
35" 6AN Braided Hose - See Above.
6AN to 7/16" Coupling - RUS-697100 - $12.39
Summery :
AER-FBM1343 x 1
AER-FCC0606 x 1
AER-FBM1122 x 3
AER-FBM2609 x 1
AER-FBM2608 x 1
RUS-697100 x 1
Old Feb 6, 2008 | 04:54 PM
jerome1979's Avatar
jerome1979
Seriously Durango Boy you ROCK !!!!
