Valve covers
Old Jan 25, 2008 | 04:54 PM
dirtyslumlord's Avatar
dirtyslumlord
Default Valve covers
This should be an easy one for the group. I installed my new zz383 crate engine a few months ago. Now I am looking to dress it up a bit w/some new valve covers. I like the early style 1955-63 covers w/fins and "corvette" in script - but they dont have an opening for a pcv valve, and consequently no drippers.
So question is: 1) does anyone know if these will fit over roller rockers(presuming I get the straight across bolt pattern); and 2) I can drill a hole in the cover, but do I need to have the drippers?
Old Jan 25, 2008 | 05:38 PM
Durango_Boy's Avatar
Durango_Boy
Do you like these?
http://www.rjays.com/Engine%20Parts/valve-covers-01.htm
Old Jan 25, 2008 | 10:14 PM
blunblk68's Avatar
blunblk68
I think you have to use Tall covers to clear roller rockers. just a heads up!
Old Jan 26, 2008 | 12:28 AM
7T9Shark's Avatar
7T9Shark
Those are sweeeeeet! Too bad they don't have a second port for the PCV and filler cap.
Old Jan 26, 2008 | 01:01 AM
GlockGuy's Avatar
GlockGuy
Originally Posted by Durango_boy
Yep, they are sweet. My buddy got them for his big block but had to return them because they would not clear the roller rockers.
Old Jan 26, 2008 | 09:35 AM
Durango_Boy
Not all roller rockers are the same, and big blocks differ a lot from small blocks. I had installed roller rockers on my 405 build, and I test fit a set of short stock Vortec center bolt valve covers and even THEY cleared the rockers I was using. I'm just saying not all roller rockers are built the same and some may fit and others won't.
Old Jan 26, 2008 | 10:07 AM
SteveG75's Avatar
SteveG75
Not too many good centerbolt valve covers. However there is a solution, but it is not exactly cheap.
GM part #24502540 are adapters that allow you to use regular perimeter bolt valve covers on a center bolt head. It also raises the valve cover about 3/8" which will give you that clearance. This will really open up your choices. Not cheap but effective. $155.88 at Summit Racing.
Trick Flow has a similiar adapter for only $102 but it has more "ribs" and requires narrow bodyy roller rockers.
Old Jan 26, 2008 | 10:56 AM
comp's Avatar
comp
Old Jan 27, 2008 | 01:24 AM
GlockGuy's Avatar
GlockGuy
I hope you are right about the sbc. These are the valve covers I have been wanting to get. I want to put them on my new trick flow heads w/roller rockers.
Old Jan 27, 2008 | 01:28 AM
Durango_Boy
Were you gonna post a link to some valve covers?
Old Jan 27, 2008 | 04:22 PM
GlockGuy's Avatar
GlockGuy
These babies. Should look familiar.
Old Jan 27, 2008 | 04:38 PM
Durango_Boy
Oh yeah, I love those. They blend with my LT1 manifold, so I have a mix of old school and new school, in a balanced relationship.
Old Jan 27, 2008 | 06:45 PM
KENS80V's Avatar
KENS80V
I've got harland sharp roller rockers under my powdercoated L82 valve covers. The drippers needed to be removed and a slight bit ground off the tips of the polly locks. I'm using S/R torquer heads though.
Old Jan 27, 2008 | 07:58 PM
GlockGuy's Avatar
GlockGuy
Cool, so if there are any interferance issues they can be resolved easily, eh?
Old Jan 27, 2008 | 08:31 PM
Durango_Boy
Well that all depends. The same roller rockers that fit under the Vortec valve covers would not fit under these finned covers. The casting of these covers is a lot thicker than the Vortec covers. I am going to have to either buy some slim design rockers, or go back to standard.
Old Jan 28, 2008 | 02:42 PM
dirtyslumlord
Does anyone know if you need to have the drippers to allow the pcv valve to work properly?
To Valve covers
