Fiber Optics
Old Jan 26, 2008 | 10:06 PM
siko123's Avatar
siko123
Default Fiber Optics
Ok.......I decided that I can"t live with dim rear fiber optic light on the console. I want to by a fiber optic sub assembly and install it. However, my carpets are brand new and I would hate to rip them up to run the wiring. Any ideas...and yes I should have replaced them before the carpets. Thanks
Old Jan 26, 2008 | 10:18 PM
tellcom2001's Avatar
tellcom2001
run a fish tape under the carpet to where you want to go..dont need to rip the carpet
Old Jan 26, 2008 | 11:09 PM
dennis's Avatar
dennis
Pretty sure the harness runs along the driver side sill on its way rearward. Hungs along up the rear pillar. all close to the carpet edge
Old Jan 26, 2008 | 11:53 PM
StickShiftCorvette's Avatar
StickShiftCorvette
At least on a '69 the rear fiber optic bundle does not follow the wiring harness. It enters the console from the rear below the three access doors so you really don't need to disrupt too much carpet, unless it routed under the rear compartment rugs.
Old Jan 27, 2008 | 02:13 AM
RippoDippo's Avatar
RippoDippo
If there Dim there still working light is passing threw the fiber,
Inspect and clean the ends, make shure there mounted correct.
Old Jan 27, 2008 | 03:15 AM
Z-man's Avatar
Z-man
Clean the ends and get the dirt out of that area on the bulbs. They might be as bright as you need. Remember, the fibers don't wear out..
Old Feb 11, 2008 | 01:37 PM
Harrykaw's Avatar
Harrykaw
To Fiber Optics
