Oil Pan Questions
Old Jan 27, 2008 | 12:32 PM
billsfan's Avatar
billsfan
Default Oil Pan Questions
I'm changing out my leaky oil pan on my '76. It has 2 wire or tubing guides welded to the side of the pan near the passenger side motor mount, plus another attached to the pan using one of the oil pan bolts. There seems to be no use for them. Any ideas why they are there? Also, my replacement pan (used but OK) has the bottom dented in slightly, the center is in about 1/4" below the sides. Will it still clear the oil pump? Or should I scrap it and go for new? Also, how do you get 30 years of engine gunk out of your eyes ???
Old Jan 27, 2008 | 12:36 PM
NTMMD8R's Avatar
NTMMD8R
Transmission cooler line clips
Old Jan 27, 2008 | 12:55 PM
billsfan's Avatar
billsfan
So someone stuck an auto tranny oil pan on my 4-speed car at one point. Thanks.
Old Jan 27, 2008 | 12:57 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Regarding the oil pan dent, you might be able to carefully knock it out with a block of wood or something similar.
Old Jan 27, 2008 | 02:27 PM
billsfan's Avatar
billsfan
Thanks. That's what I plan to do. It must be a common problem, cause my existing pan has scrapes and dents in it.
Old Jan 27, 2008 | 02:36 PM
Jud Chapin's Avatar
Jud Chapin
Yep, a lot of these Vettes have been to Hell and back and bottoming out hitting the pan was part of it. If you've got a buddy in the auto body business, I bet he could get it to look as though it was never hit with the tools they have.
Old Jan 27, 2008 | 02:45 PM
69small block's Avatar
69small block
sounds like auto oil pan
regarding 30 year old gunk some times glasses of the saftey nature are helpful yes a pita but do help sometimes and good luck with the pan
Old Jan 27, 2008 | 02:47 PM
jsrajca's Avatar
jsrajca
I was just going to post an oil pan ? I just put my 75 up on home made ramp(works great and i feel safer under it 2+12") I noticed my oil pan coated with oil not to bad but looking quick,can you just drop pan or is there a motor lift out proceses?? thanks Johnny r
Old Jan 27, 2008 | 02:53 PM
TopGunn's Avatar
TopGunn
Remove the two bolts from the idler arm on the passenger side and the steering linkage will drop down far enough to get the pan off easily.
Old Jan 27, 2008 | 11:38 PM
682XLR8's Avatar
682XLR8
Just did this yesterday on another Forum members car. Pan drops down and back. Replace the gasket with a Fel-pro 1-piece
Old Jan 28, 2008 | 07:34 AM
Paul L's Avatar
Paul L
As stated, transmission tubes.
Old Jan 28, 2008 | 07:55 AM
Jud Chapin's Avatar
Jud Chapin
Replace the rear main seal while you are at it.
To Oil Pan Questions
