tire sizing
Old Jan 30, 2008 | 12:01 PM
1tuffref's Avatar
1tuffref
Default tire sizing
I went to 16" wheels on my 77 and now I need new rubber. I know the current tires are a little undersized, height, at P245/50zr16. What would be a good size to get me back to a stock stance and accurate speedometer?
Old Jan 30, 2008 | 02:08 PM
hugie82's Avatar
hugie82
I went with 255/60-15 and that is as big as I can go without hitting. look up this tire and you will get the diameter and with and just cross refference. Make sure your back spacing is the same as stock or you may have problems.
Old Jan 30, 2008 | 02:34 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Try this link,
http://www.miata.net/garage/tirecalc.html
Old Jan 30, 2008 | 02:51 PM
blckslvr79's Avatar
blckslvr79
Originally Posted by Glass Act
255/55 16 per that weblink
Is that an actual size?
Old Jan 30, 2008 | 03:00 PM
Glass Act's Avatar
Glass Act
Yes, that is an actual tire size in 16's
Old Jan 30, 2008 | 04:08 PM
1tuffref's Avatar
1tuffref
Anybody get a 265/55-16 in there? It looks like they are only over by .100". I already went through the back spacing thing when I bought the wheels and had to add stand off spacers, yes they are the bolt on type, so I should be set.
Old Jan 30, 2008 | 04:33 PM
Glass Act's Avatar
Glass Act
1tuffref,
What size tires did you have on the car, or have now.
Old Jan 30, 2008 | 04:41 PM
blckslvr79's Avatar
blckslvr79
1tuffref,
P245/50zr16
per original post
Old Jan 30, 2008 | 05:01 PM
Glass Act's Avatar
Glass Act
Size now 245/50X16 = 25.6 in. tall
The best size would be,
225/55X16 = 25.2 in. tall
Old Jan 30, 2008 | 06:00 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
For anyone interested...
http://www.rogerkrausracing.com/Tech.../tiredem.shtml
Old Feb 5, 2008 | 10:52 AM
1tuffref's Avatar
1tuffref
Ok, I found it. the original tires, factory, were 225/70-15 so the original tire diameter was 27.4 inches. It looks like the best fit to get me to the correct diameter on my 16 inch wheels would be a 265/55-16 tire that has a diameter of 27.5 inches. My question is has anybody put these on their car?
Old Feb 5, 2008 | 01:55 PM
carbster09's Avatar
carbster09
Default Same problem here.
I have gone with 16"'s as well. I ended up fitting 235/50/16's front and 255/50/16's rear. We really need a 55 series tire. BUT you cannot get there. There is a truck/suv tire, but whats the point? I might lower the car a touch or go back to 15's? I have a tire calc so I can compare diameters. I don't know if 255/60's will fit well, any opinions?
carbster
Old Feb 5, 2008 | 10:56 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
I was looking at 16" wheels/tires but as you said tire selection is poor in 27" diameter. I think a 255/55 is the size you want. One choice on Tire Rack.
http://www.tirerack.com/tires/Compar...t=All&x=67&y=8
That is why I am going to 17". Better tire selection.
http://www.tirerack.com/tires/Compar...=All&x=64&y=13
Old Feb 5, 2008 | 11:05 PM
Sky65's Avatar
Sky65
Just looked again and found these. 235/60 16. It would be interesting to see how the sidewall looked on these on a 8" rim.
http://www.tirerack.com/tires/Compar...t=All&x=67&y=7
Old Feb 6, 2008 | 12:02 AM
TheSkunkWorks
They ought to work just fine, as that should prove to fall right in the middle of the recommended rim widths, the height should be 27", and the tread about 8.2".
Old Feb 14, 2008 | 09:26 AM
1tuffref's Avatar
1tuffref
I'm going with the 235/60-16 size. It will be an improvement on the ride height I have now and the suspension needs a total replacement anyway. Maybe next summer. The diameter is off by .30" and I can deal. I ended up with the 16 inch wheels because I wanted centerline champ 500s (with the spinners) and they don't make them any more. I ended up getting them off ebay w/rubber and lugs for under $800. Trust me after I got them polished up and on the car I was very happy with the look. If I could have found 15" wheels the right width I probably would have gone with them but I was looking for a long time for four and couldn't find them. 17" wheels is this style were not even on the radar.
Old Feb 14, 2008 | 10:07 AM
Sky65's Avatar
Sky65
Post some pics when you get them mounted.
Old Feb 15, 2008 | 04:12 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'm running 235/50-17's (26.6" tall) on 17"x8" wheels and they look good, so I would think 235/60 would look fine on a 16"x8" rim.
This is the only picture I have right now, ... regretfully, its not very good.
Old Feb 19, 2008 | 01:31 PM
1tuffref's Avatar
1tuffref
Sure, but not until I polish the wheels and spinners. Thanks for the help guys.
To tire sizing
