new transmission
Old Jan 30, 2008 | 01:00 PM
tigers123's Avatar
tigers123
Default new transmission
Anybody considered the new automatic from Keisler? The install looks a little easier than the earlier overdrives. I'm wondering about the quality of the trans from GM [4l60e] If anybody has any input on either I would like to hear it. This automatic is a little cheaper and easier than the 5 speed install and might be what I'm looking for if the tranny is tough enough. I've shied away from the 200 r4 and the 700r4 as I think they might be a little light weight. I have a drooling leaking sluggish th400 and think this trans may be a little better. I'm putting this behind a 383 short block from the General of Motors that has Afr 195's and an lt4 hot cam. TIA
Old Jan 30, 2008 | 02:05 PM
SIXFOOTER's Avatar
SIXFOOTER
4L60E is a Very nice transmission. You will need a controller for it. A cool thing is all the shift points are programable.
Old Jan 30, 2008 | 06:31 PM
tigers123's Avatar
tigers123
Yeah the kit comes with a controller, driveshaft, crossmember, flywheel etc. I don't think they left too many things out. I was just wondering if this trans is just as beefy as the th400 and reliable.
Old Jan 31, 2008 | 04:44 PM
GENE-KEISLER SALES's Avatar
0GENE-KEISLER SALES
Former Vendor
Default Keisler 4 psd Auto
Here is a little information.
We have 3 power ratings.
450 ft lbs Stage 1
550 ft lbs Stage 2
650 ft lbs Stage 3
The trans are all dyno tested and come complete with all the parts needed to do the job. There is no mods needed to the car and the shifter even looks stock when finished.
Here is an article about installing one into a C3
http://www.keislerauto.com/images/Ma...usiast0208.pdf
Thanks Gene
Old Jan 31, 2008 | 05:36 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
I hope it has the sonnax valve fix. This is the same tranny in my 2000 camaro and at about 80k i threw a code and the torque converter is having trouble locking up due to that sonnax valve and tq lock up sensor.
To new transmission
