Dual Exhaust
Old Jan 30, 2008 | 06:46 PM
ledzep4788's Avatar
ledzep4788
8th Gear
Default Dual Exhaust
I have an 80' and I want to upgrade to a true dual exhaust from my stock system and I was wondering if a system from a 74' would work or if I would be better off getting custom pipes bent.
Old Jan 30, 2008 | 06:53 PM
mikep3's Avatar
mikep3
Default Dual Upgrade
You first need to look at local laws.
I went to one of our vendors and got one of these for my 78.
http://www.corvettecentralexhaust.com/c3perfdual.htm
With that and recurve on the distributor the car has power and smooth on acceleration. Its that simple.
Old Jan 30, 2008 | 08:15 PM
stock76's Avatar
stock76
I'm not sure about an 80. Does the crossmember have the holes for duals? My 76 did and the dual system from Corvette Central bolted right up to the stock exhaust manifolds with no problem. If in doubt give them a call.
Old Jan 30, 2008 | 08:19 PM
MN80Vette's Avatar
MN80Vette
Your profile isn't filled out so we don't know where you live. As mikep3 said, you need to check you local laws to verify a true dual is OK. IF the laws where you live allow, I highly recommend full length ceramic coated headers and a custom bent true dual exhaust. A number of CF members (including me) had major fit problems with a prebent system. I gave up and went with a custom bend system with a cross-over pipe. PERFECT!
Old Jan 30, 2008 | 09:50 PM
ledzep4788's Avatar
ledzep4788
8th Gear
I'm in PA and I know my local laws allow for true duals as long as I have an antique plate on it. I just know for sure that I can get a true dual system for a 74' but it doesn't say anything about an 80' obviously for legal reasons. I just have the fake duals now.
Old Jan 30, 2008 | 09:56 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Is there NOT a local muffler shop for you to go to? It's not too involved if they can do some mandrel bends and put a crossover pipe behind the crossmember.
That would cost you less at a muffler shop, than duals thru any vendor.
Old Jan 30, 2008 | 10:53 PM
ledzep4788's Avatar
ledzep4788
8th Gear
Ya there is local muffler shops around but I don't know if they have machine to do mandrel bends or not. I would think so, but also I don't know if they have the high quality stainless steel. I'm planning on looking more into it but I was just inquiring about what you guys think. Thanks for the suggestions!
Old Jan 30, 2008 | 10:55 PM
mikep3's Avatar
mikep3
I looked at the link,
The later years 79 to 82 have the both pipes going down one side. My 78 has two holes in the cross member and was supplied with just four pipes, two from the engine to cross member and two from cross member to the stock mufflers.
Old Jan 31, 2008 | 12:38 AM
MN80Vette's Avatar
MN80Vette
If your upgrade is going to include full length headers, a dual pipe system that runs both pipes to the right side like stock won't work very well because of the bend the driver's side pipe will need to make behind the header to get to the right side. How do I know? I had dual pipes with block hugger headers (that melted my motor mounts) that both went back on the right side. When I swapped out the block huggers for full lengths, the bend to route the left pipe to the right side was too sharp as you can see om the pic below. (You can also see the cutout where the new left pipe is going to go.)
A simple modification to your cross member will give you the ground clearance you need on the left side. That was one of the best mods I made to my '80. I can tell you exactly how to modify the cross member to route the left pipe similar to the right pipe in the stock location. Check my other posts for more info, or PM me with your e-mail address so I can send you a link to more pics of my exhaust with full length ceramic coated Dynomax headers and custom 2 1/2" pipes to Flo-Pro baffled mufflers. I have a video with sound so you can here this setup too.
Old Jan 31, 2008 | 02:24 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Old Jan 31, 2008 | 04:26 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Actually, per federal law, you can never run a dual exhaust. Your car came with one catalytic converter and that is the only LEGAL setup you can use.
However, that doesn't stop very many people. I'm considering this kit http://www.mamotorworks.com/corvette-4-36-1303.html I am also considering adding a single 3" cat in the appropriate location with a set of 2-2.5" to 3" Y's to make it work.
Old Jan 31, 2008 | 07:01 PM
billsfan's Avatar
billsfan
Not quite right. Go to the DMV site for your State and check the emissions requirements. In New York, emmissions equipment is not needed on 25 year old cars, and NY is a pretty strict State.
Old Jan 31, 2008 | 09:11 PM
mikep3's Avatar
mikep3
Hey MN80Vet, How were the shorty headers, were they worth putting on over the Ram Horn cast iron things?
Old Jan 31, 2008 | 09:20 PM
ledzep4788's Avatar
ledzep4788
8th Gear
Ya in PA it is legal for a car 20 or 25 years old, I'm not sure, to have true duals but you have to pay for a antique license plate and there are restrictions as to when you can drive and how far you can drive a year, but it also makes the insurance quite a bit cheaper. Thanks for all the help. I know for sure I want to get headers, I just have to talk to the guys at the local muffler shop to see what it would cost there. Thanks again!
Old Jan 31, 2008 | 10:14 PM
MN80Vette's Avatar
MN80Vette
The block huggers were bad news. They fried 4 sets of spark plug wires, they melted the poly pads in both motor mounts, and I had to remove the headers to change the spark plugs. Nuf said?
Old Feb 1, 2008 | 06:16 AM
stingr69's Avatar
stingr69
On the left - what you got
On the right - what you need
-Mark.
Old Feb 1, 2008 | 07:02 AM
mikep3's Avatar
mikep3
Default Thanks for the head up
Well, I guess that we need to clean and paint the cast iron ram horns on my vortec head change.
To Dual Exhaust
Old Feb 1, 2008 | 07:38 AM
MN80Vette's Avatar
MN80Vette
That's the least expensive option for sure but not your only option. The problem with block huggers is that the collector is centered between 3-5 and 4-6 and close to the block - an inch behind the motor mounts. I had stainless steel block huggers, not ceramic coated. They were hot. The red poly in the Energy motor mounts literally boiled.
In comparison, the Dynomax full length ceramic headers I switched to are swept back from center. They also come farther out from the exhaust ports before going down giving better room for spark plug access. I saw some shorty headers that were swept back and had good plug access too. Hugging the block is not a priority for some headers.
Old Feb 1, 2008 | 10:05 AM
Ak. Mal's Avatar
Ak. Mal
-Mark.
I tried to PM you, but your inbox is full. Is that the exhaust that I'm asking about in this thread http://forums.corvetteforum.com/show....php?t=1928426 ?
Old Feb 1, 2008 | 11:41 AM
stingr69's Avatar
stingr69
AK Mal,
Yes that is the MAD True Duals setup with (2) Dynomax C3 Vette muffs. It took a bit of work to get it to fit and I had to MIG it together as it is very thick. I would probably buy one again if I ever needed one.
I also added a crossover to that system later where the 2 pipes run close together. The sound chage when I added the crossover was not much with this combination. The performance change from adding the crossover was also minimal with this particular setup running the stock 350/350 cam.
I have had more substantial results when adding crossovers on combinations where the exhaust system was more taxed. I expect that was due to the narrower lobe centers/duration issues with the other engine. The setup that did show an improvement also had long tube headers and performance muffs. The crossover effects were more pronounced with that setup. Your results may vary.
I saw where you were trying to run dual cats. I would not do that personaly. I might be more inclined to run stock pipes with a single high flow cat if you will need to have the emissions equipment. I know that will fit and work well for you.
-Mark.
