front emblem
Old Dec 1, 2001 | 07:29 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default front emblem
I am in process of stripping all the paint for a repaint and can't see how the front emblem comes off.I got underneath and it seems like it is held on by a plate attached to the front nose mount but I don't see any nuts through the plate to the emblem.It's like it is tac welded to the plate but cant see that.
Anyone know about this?
Thanks for the help. Wave on \ ////
Old Dec 1, 2001 | 10:01 PM
jerryp58's Avatar
jerryp58
Default Re: front emblem (all smiles 81)
My '77s nose emblem (from Zip or Mid-America) is held on by two sided tape. There are a couple of protrusions (1/4" or so) that go into two holes in the nose, but there's nothing attached to them from behind the bumper.
Old Dec 2, 2001 | 02:40 PM
Ben Taylor's Avatar
Ben Taylor
Mine came off when someone ran into my parked car, you could try that.
Old Dec 2, 2001 | 02:43 PM
VettePaul's Avatar
VettePaul
It's just stuck on with double sided tape. :boxing
Old Dec 2, 2001 | 03:28 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: front emblem (VettePaul)
Well instead of having someone run into me, I guess I will pry it off.I thought it might have been just glued on but didn't want to tear anything up trying to pry it off.thatnks for the help all.
wave on. \ ////
Old Dec 3, 2001 | 05:12 PM
82dukman's Avatar
82dukman
Don't pry it off. Use either a piece of dental floss or fishing line. Put it under a corner of the emblem and make it long enough so you can do a "sawing" motion, up and down. That will cut through the tape and not damage the paint. Just my .02(through experience) :seeya
Old Dec 3, 2001 | 05:33 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: front emblem (82dukman)
Also, heating it up with a hairdryer will loosen it up.
Old Dec 3, 2001 | 08:54 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: front emblem (Rhys)
yeah it did take some of the paint up but like I said I am stripping all the paint anyway.
To front emblem
