new engine oils?
Old Feb 2, 2008 | 01:29 AM
jack 69's Avatar
jack 69
Default new engine oils?
i just lost my cam after 12,000 miles.... mobil 1 15/50... so i did some checking and found this www.ttalk.info/zddp.htm
try typing in zddp in your search engine and read
numbers matching 69 B/B vert
Old Feb 2, 2008 | 04:24 AM
jerrylee's Avatar
jerrylee
That was a good read n it makes me feel good especially since I chose to go with Redline after my engine ws broken in...About 1,000 miles since switching to Redline now n all systems are running great....Thanx ...Jerrylee///
Old Feb 2, 2008 | 06:38 AM
jazz81's Avatar
jazz81
Great reading. As i am in the middle of a rebuilt, this will help me thru the initial breakin and longevity of the engine.
Thanks for the post
jazz81
Old Feb 2, 2008 | 08:35 AM
69small block's Avatar
69small block
Default oil
where can you get redline
and does lucas oil stablizer have this ZDDP in it
Old Feb 2, 2008 | 09:09 AM
MN80Vette's Avatar
MN80Vette
That's one of the best oil articles I've read. The Mobil1 web site has a chart that includes the ZDDP levels of each or their oils. If I stick with Mobil1, I am switching to one of their motorcycle oils.
Old Feb 2, 2008 | 09:10 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
There are lots of oils out there that contain enough ZDDP. A few examples are
Mobile 1 High Mileage
Castrol GTX 20W-50
Castrol GTX High Mileage 20W-50 or -40
And all diesel oils no matter what brand. On older engines we need ZDDP and the new oils GF-4 grades do not contain it.
This may sound odd and I'm sure some may argue, but I've run diesel oils ever since the government made oil companies lower or remove ZPPD (zinc) without issues. My cams and internal componets are fine, no signs of abnormal wear, only because of the higher ZDDP in the oils I use. Todays oils are not meant for our older engines
Next time your at your auto store, pick up a bottle of diesel or a high mileage oil and read it's contents, racing oils are also good.
Old Feb 2, 2008 | 10:28 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Default Interesting Post
Does anyone have any in depth knowledge regarding the oil additive "ZMAX? I watched a segment on "Speed" and they hyped it up which is no surprise. Just wondering if it is what they all say it is. Thanx all.
Old Feb 2, 2008 | 10:39 AM
Glass Act's Avatar
Glass Act
Two things, I do not believe in any additives, they are products we really don't need and a company likes sales. (my 0.2)
Second, ZMAX is an additive that the FTC (Federal Trade Commission) sued for false or misleading advertising of their product. This takes me back to my first reason, it's not needed and most aren't or do what they say.
Old Feb 2, 2008 | 10:54 AM
jerrylee's Avatar
jerrylee
[QUOTE=69small block;1563915456]where can you get redline.
Jegs or Summit....you can even go to Redline direct....That's all I use in my Vette n Impala......Jerrylee///
Old Feb 2, 2008 | 10:56 AM
jerrylee's Avatar
jerrylee
Never use additives.....It's a big con...Jerrylee///
Old Feb 2, 2008 | 11:18 AM
HOOAH's Avatar
HOOAH
Default Thanx for the feedback (oil additives)
Thank you very much for the info. I "was" a believer but when I went to the local Autozone ands saw the 35 dollar pricetag for the additive, I decided to come back to where I knew I would get the right answer. This forum is awsome!!! Thanx again everyone!!!
Old Feb 2, 2008 | 11:32 AM
jackson's Avatar
jackson
Except ... GM EOS ... it has the additive pack(wear metals) that're missing from most modern oils. Flat tappet lifters require the missing pack ... roller lifters do not. Rotella T 15W-40 WITH a bottle of GM EOS is good for flat tappet breakin ... thereafter straight Rotella ... or your pick mixed w/ a half-bottle of GM EOS. Yes, newest Rotella (CJ) reduced wear packs in 2007, but there's still plenty there in CJ.
Old Feb 2, 2008 | 01:01 PM
jack 69's Avatar
jack 69
i was told by a local speed shop that GM no longer sells E.O.S.
a friend called the Chevy dealer and asked, there reply was, they no longer sell E.O.S.
Old Feb 2, 2008 | 01:17 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A recent article in Auto Restorer said that STP engine oil additive has a bunch of ZDDP in it - more than enough to replace what's missing in modern oils.
Old Feb 2, 2008 | 02:04 PM
jackson's Avatar
jackson
I last bought some from local GM just last year (2007) ... maybe it was old stock ... I've since heard GM still sells it but its part number has changed ... but have not verified w/ local GM.
Old Feb 2, 2008 | 02:05 PM
another-user's Avatar
another-user
so whats the recommended oil out there now? and preferably something that isnt ungodly expensive.
i was using Rotella but ive heard they changed for the new standards and its no longer suitable to use.
Old Feb 2, 2008 | 02:40 PM
jackson's Avatar
jackson
"new" Rotella AOK ... it was reduced but only slightly ... diesel cats not like gas cats ... new Rotella 15W-40 CJ4 still has plenty of wear additives.
EOS p/n did change from old p/n 1052367 to new p/n 88862586
To new engine oils?
Old Feb 2, 2008 | 04:41 PM
bumperkar kid's Avatar
bumperkar kid
hey mikey....sorry to hear about "jack". put "jack" away for the winter and start using "leena"!!!
Old Feb 2, 2008 | 07:29 PM
Roughrider's Avatar
Roughrider
GM does sell EOS again...but it's been reformulated. Suuposedly it has less ZDDP than before but still has it.
For what it's worth, a local GM dealer parts manager said EOS is essentially GM's version of STP.
Old Feb 2, 2008 | 09:11 PM
gve's Avatar
gve
Check this out on chevelle forum,Scott paid a lab to test different oils for zinc etc. Go to the last page, this thread has been going on for a long time, its interesting. http://www.chevelles.com/forums/showthread.php?t=195620
