Idler arm question
Old Feb 2, 2008 | 07:08 PM
76projectstingray's Avatar
76projectstingray
Default Idler arm question
I bought a new Idler arm and it came with a foam cusion washer. I assume it goes between the idler arm and the steering rod. Is there supposed to be a plastic and rubber washer to go between the idler arm and the sterring rod?
Old Feb 2, 2008 | 11:15 PM
maddmickey's Avatar
maddmickey
I have seen those come with a ruber seal, like on a ball joint, and sometimes they come with that foam piece. whitch ever one it came with you should be fine. It just keeps dirt out.
Old Feb 3, 2008 | 10:54 AM
A88FXRS's Avatar
A88FXRS
I Just Split A 69 Front End Apart Last Week. The Idler Arm Had A Thick Black Rubber Washer And A Blue Plastic Washer Between The Joint. Hope This Helps
Old Feb 3, 2008 | 04:18 PM
76projectstingray
I bought the Idler arm from zips , it shows the rubber gasket and the plastic washer as an extra order #. but it gave the black sponge washer with the kit. If you needed the rubber and plastic one you would think it would come with the new arm?
Old Feb 3, 2008 | 08:07 PM
A88FXRS's Avatar
A88FXRS
That Would Be Too Easy
To Idler arm question
