engine wont turn off - update
Old Feb 3, 2008 | 11:15 AM
bloater's Avatar
bloater
Default engine wont turn off - update
Update as promised. problem sorted!!!!!!! Something as simple as an earth wire feeding into the live on the starter motor.This was causing a continuous supply to the distributor, by-passing the ignition switch, so there was no effect when turning ignition off (engine continuing to run)
I have re-routed the earth well away from starter circuit and eveything is working exactly the way it should.Many thanks for the advice offered yesterday.
