cylinder walls
Old Feb 3, 2008 | 04:21 PM
Tina69's Avatar
Tina69
Default cylinder walls
Hey folks, just doing a little work in the garage before the game starts. My question is: What do you folks use when cleaning up the top end of your cylinder walls? I am talking about the small carbon build up not a ridge. Just pulled the heads and have some carbon build up. Just wondering what you folks do? I have some ideas already but am open to new ones.
Thanks in advance for any input
Old Feb 3, 2008 | 05:35 PM
ENG40's Avatar
ENG40
I would use a putty knife and then a wire brush, just be careful not to gouge the cylinder wall.
Old Feb 3, 2008 | 08:05 PM
A88FXRS's Avatar
A88FXRS
Ball Hone With The Piston Down Low And A Rag On Top.
Old Feb 3, 2008 | 08:32 PM
Duke94's Avatar
Duke94
Ridge reamer.
http://www.autozone.com/in_our_store...dge_reamer.htm
Old Feb 3, 2008 | 09:24 PM
noonie's Avatar
noonie
If it really only is carbon,
razor blades.
Old Feb 3, 2008 | 11:50 PM
Rustbucket79's Avatar
Rustbucket79
Are you planning to pull out the pistons? If the shortblock is staying together, that carbon is taking up wasted airspace between the piston and cylinder at TDC and isn't hurting anything.
Old Feb 4, 2008 | 12:51 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
yep. I would not use a ball hone or a ridge reamer unless I was pulling the slugs outta the block.
Old Feb 4, 2008 | 04:17 AM
stingr69's Avatar
stingr69
Messing with it will cause more harm than good.
-Mark.
Old Feb 4, 2008 | 06:28 AM
L88Plus's Avatar
L88Plus
I dont' care how meticulous and clean you are, you'll leave trash in the gap between the piston and cylinder wall. That'll scuff your cylinder walls and ruin your ring seals. I've seen it happen many times during head swaps. More power initially, but then it drops as the trash on that top ring land does it's damage. Leave it alone, it's not hurting anything.
Old Feb 4, 2008 | 01:54 PM
Solid LT1's Avatar
Solid LT1
Try some ATF like we use on freshly honed cylinders.
To cylinder walls
