Back Brake Noisy
Old Feb 4, 2008 | 10:26 PM
Ward72's Avatar
Ward72
Default Back Brake Noisy
I just purchased my first Vette, a 1972. All is good. However, the rear passenger brake is making a dragging sound that goes away when the brakes are pressed. The rotors look good and the pads look new. Any ideas!
Old Feb 4, 2008 | 10:46 PM
Durango_Boy's Avatar
Durango_Boy
I would guess one or more of the piston return springs are bad or broken, which in turn does not keep the normal amount of pad pressure on the rotor.
Any idea of the age of the components? If they are the stock calipers they might need to be rebuilt and retrofitted with stainless steel sleeves in the piston bores.
Old Feb 5, 2008 | 12:14 AM
Ward72's Avatar
Ward72
The previous owner said they were rebuilt ~3 yrs ago.
Old Feb 5, 2008 | 01:43 AM
ajkogut's Avatar
ajkogut
Dragging parking brake shoe? The problem wouldn't necessarily go away when you hit the brakes but its possible. May want to add it to your list.
Old Feb 5, 2008 | 08:23 AM
Durango_Boy
Just a thought, but some people opt to leave the springs out when they rebuild the calipers. Maybe you have that kind of a situation. Any chance you can contact that previous owner?
Old Feb 5, 2008 | 08:39 AM
dannyman's Avatar
dannyman
I would adjust the parking brake and see if that eliminates the noise.
Old Feb 5, 2008 | 08:42 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
My 72 coupe does the exact same thing.
The harder I press the brake pedal, the quieter it gets.
Gently pulling up on the park brake has no effect.
I am guessing the rotor is slightly warped.
I suspect fresh rotors and pads will fix. We shall see.
Old Feb 5, 2008 | 12:04 PM
stock76's Avatar
stock76
Also check this: one, or both of the parking brake return springs could have rusted through, broken, fallen out and be rubbing against the inside of the rotor hub. Also, If the rivets were drilled out to replace the rotors, check to see if one didn't fall down inside and catch on something and now be rubbing on the inside of the rotor hub. I thought I had mine all accounted for when I drilled them out. A few days later I started getting a loud scraping sound from the passenger side rear. Expecting the worst, I pulled off the rotor, and there it was; a loose piece of drilled out rivet was causing the noise by rubbing against the inside of the rotor. It must have wedged itself between the parking brake shoe. Whew! Fortunately the rivets are a lot softer than Rotor steel so nothing was hurt. Hope that is all that is wrong with yours.
Old Feb 5, 2008 | 01:50 PM
in2fun's Avatar
in2fun
You guys, my 72 coupe does the exact same thing. I have not had a chance to look at it yet. The pads are new, rotors are new, Brake clipers rebuilt a year ago. I'm planing on looking at it next week. if I come up with somthing I'll let you guys know. Mine is also the right rear.
Old Feb 5, 2008 | 10:42 PM
Ward72's Avatar
Ward72
Well, it looks like I have this weekend's project planned out. I'll look for material. There is a Vette supplier in town I'll take the rotor and caliper and what ever else I can tear off too for a look. Let you know what I find out. Thanks for the info....
To Back Brake Noisy
