Can the rear wheel bearings be lubricated without taking the trailing arm assembly apart. I have them out of the car and was just going to paint them- but I thought if they can be lubricated why not? When I say take them apart- I mean to the point where you need special tools to put them back together.
Anyone do this??
Reason: clarification
The only way to grease them is to pull them completely apart and repack the bearings. At that point, I would get new bearings. You can't drill a hole and put a zerk fitting in the bearing support. You'll just blow the seals out if you put too much in.
There is a tool that you can buy from almost all the suppliers which allows you to grease the spindles without taking them all apart. You need to take the half shafts off and what looks like the inside spindle nut, put the tool on, grease, put the nut on and torgue and install the half shafts back on. This is the tool that is mentioned in the GM shop Service Manual. I have the tool but have not used it yet as I am waiting when I R&R the Universal joints in the spring. Corvette central part # 582416. Beware the instructions suck as I thing they think you will use the GM shop manual. I would like to know if anyone has used this tool.
I have that tool too....never used...probably never will after Dan explained the whole the deal. These guys know these rear ends inside and out....excellent folks. I plan to install rebuilt arms from them soon.
The type of grease used is quite important for long bearing life.
The tool doesn't work!
Taking the spindle apart is not an easy job and requires special tools to reassemble the spindle properly. Be careful and good luck!
i have one if you need it, just pay the ups, keep in mind you are throwing away your money all these tools are good for is finding out when you go to use them there is too much play and they need to be pulled and replaced anyway-save yourself some time and just replace the bearings and seals. if you follow the gm service manual it is 3 pumps on the grease gun, if you follow the more is better rule it just pushs out the outer seal and it is going to need to be replaced at that point
There is a tool that you can buy from almost all the suppliers which allows you to grease the spindles without taking them all apart...
As I understand it, the tool only greases one half of the bearings and not the other side. Plus you run the risk of putting in too much grease, risking the seals on that side.
Do yourself a favor and don't do it. If you doubt the condition of your beargings, have them professionally rebuilt.
If you have them out, I would send them to Van steel for a rebuild. Too much stuff has to be pulled for you to have to do it later, if they later go bad, on the car, this is especially true if they are the originals, and havn't ever been rebuilt before. i believe, if you send the rotors with them, or better yet, have them add new rotors there (shipping savings, and rotors are cheap) they will true them to the rotation when they rebuild them. I had mine done at the local chevy dealer on the car, then had the rotors turned on the car to true them. a good investment. I would also replace the U-joints with spicer solids, "while your at it".
my cars rear end let a bearing go about 3 years ago in a big hurry and almost shook the steering wheel out of my hands. i contimplated buying a left and a right at the same time thinking if one has gone , more than likely the other will go but i didnt . i just got the one complete bearing assembly from van steel , bolted it on and havent had any trouble since, and i flog the absolute *&%$ out of it...im glad i didnt do the other cause it hasnt gone yet touch wood 3 years later.my shipping to aust was more than the bearing itself haha
send to van steel,a supporting member, they specialize in rear bearing lube and end play adjustment.you can call them and find out what all you can take off to save shipping weight. they're in south florida and have done work for me
