Lower shock bolts
Old Feb 10, 2008 | 02:25 PM
stingrayrick76's Avatar
stingrayrick76
Default Lower shock bolts
I'm trying to take out the rear lower shock bolts. I bought the tool from vbp still will not budge. Any suggestions ie; bigger hammer!
Old Feb 10, 2008 | 02:35 PM
FRSTR90's Avatar
FRSTR90
Oxy/Ace Torch - Don't cut it off just heat it. Then use a hammer to beat it out.
Old Feb 10, 2008 | 02:38 PM
A88FXRS's Avatar
A88FXRS
Just Did Two Yesterday Morning. Heat And Pressed Them Out. Came Apart Fairly Easily. Bearing Carrier Was Removed From Trailing Arm.
Old Feb 10, 2008 | 02:40 PM
wallifishrmn's Avatar
wallifishrmn
Just removed my rear trailings, shocks, etc. I just had to use a big hammer and kroil. Figured the worst that would happen is I would ruin it and have to buy a new one--didn't have much choice--had to get it loose.
Old Feb 10, 2008 | 04:35 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
It helps to soak them in blaster overnight too.
Old Feb 10, 2008 | 06:18 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
To Lower shock bolts
