First impressions with the spool...
Old Feb 10, 2008 | 08:11 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default First impressions with the spool...
Installed a spool differential (3.73 gears) in my '68 this week.. Went from a 4.11 posi to a 3.73 spool in my Tom's 12-bolt setup.. There was no major effect on the ET's but I didn't expect a huge difference. The main benefit of a spool setup is strength.. I was initially worried about making turns with the spool, but after driving around the pits a little bit, I didn't see a major problem. Turns just fine... Of course, you can feel some resistence when making turns but it's not too bad..
Old Feb 10, 2008 | 09:24 PM
brngrhd's Avatar
brngrhd
cool. now go out and try pushing the car and making a turn LOL. i have pushed one before it sucks.
Old Feb 10, 2008 | 10:36 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I forgot about the new spool and 3.73's. Didn't seem to matter either way did it? Looks like MPH stayed the same and the ET actually improved a hair.
What RPM are you at in the traps at 144??
JIM
Old Feb 10, 2008 | 10:46 PM
GrandSportC3
JIM
I'm trapping at about 6900 RPM, just shy of hitting the rev limiter at 7000 RPM.. I'll raise the rev limiter once I run a bigger shot..
Old Feb 10, 2008 | 10:52 PM
427Hotrod's Avatar
427Hotrod
Aww c'mon....I'm spinning the 540 higher than that! Let's wing that thing a little!!
JIM
Old Feb 10, 2008 | 10:57 PM
GrandSportC3
JIM
The engine is built to hold up to 8000 RPM but I really want to get some life out of it.. The engine also peaks at 6000 RPM and falls off after 7000 RPM. Long stroke small blocks don't like high RPM's too much.. It's not like a 377 (4.155 bore and 3.48 stroke) that revs to 8000+...
Old Feb 10, 2008 | 11:22 PM
427Hotrod's Avatar
427Hotrod
It'll like high RPM when you put the big heads on it some day!
Did it handle better with the new slicks?
Have you tried blocking off grille area to see if it goes faster?
JIM
Old Feb 10, 2008 | 11:24 PM
GrandSportC3
JIM
I'm thinking in switching to either 18 degree heads or SB2.2 heads in 1 - 2 seasons..
To First impressions with the spool...
