weight difference BBC/SBC?
Old Feb 11, 2008 | 03:40 AM
Ronaldo's Avatar
Ronaldo
Default weight difference BBC/SBC?
How big would the weight difference be from a stock 350 SB, with iron intake, copper radiator, iron waterpump to a 454 BB, with alu heads, alu intake, alu waterpumpe, alu radiator?
Old Feb 11, 2008 | 07:14 AM
Durango_Boy's Avatar
Durango_Boy
Maybe 60 lbs?
Old Feb 11, 2008 | 08:04 AM
rihwoods's Avatar
rihwoods
My 78 SA L-82 weighs 3580 LBS....A/C,P/S
My 69 Coupe 502 weighs 3370 Lbs...P/S,No A/C
Old Feb 11, 2008 | 08:54 AM
Aggitated Monkey's Avatar
Aggitated Monkey
Castiron for Castiron I beleve shold be 150lbs and the BB is 1.5" longer than the SB with thadded length from the mount forward.
Old Feb 11, 2008 | 10:53 AM
rihwoods's Avatar
rihwoods
These weights may help...
350 small block....575 LBS...
454 cast iron.......685 Lbs
427 ZR1 Aluminum block...550 Lbs..
I figure my ZZ502 to be between the 350/454....approx..600 LBS or so...
Old Feb 11, 2008 | 01:46 PM
Ronaldo's Avatar
Ronaldo
thanks for all the answers. Will my SB car drive much different with a cast iron big block with alu heads/intake?
Old Feb 11, 2008 | 02:14 PM
Durango_Boy
No not too much of a difference I wouldn't think. If nothing else you MAY have to replace the front springs with some big block springs but I doubt that.
Old Feb 11, 2008 | 03:06 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
Don't quote me on the specifics here, but...
Front springs will have to be replaced for the extra weight. VBP sells a mid-range set of 400ish pounds and actually lowers it by 1 inch. F-41 springs were 500+ I think, where as stock were under 300 pounds.
Also note, most BB Vettes had a rear anti-sway bar.
As for handeling...the shear dynamics of the mass & weight physics would suggest there will be some handeling diffrences. Heat buildup, fuel economy, Corvette envy, increases in traffic violations and a host of other factors come into play when upgrading to a BB.
Old Feb 12, 2008 | 09:06 AM
CCrane65's Avatar
CCrane65
Rowdy Rat sent me the following information:
Front Springs:
350 (no A/C) - Part #3931823 - "HS" - 250 lbs/in
350 (with A/C) - Part #3931824 - "HT" - 264 lbs/in
454 (no A/C) - Part #3931825 - "HU" -284 lbs/in
454 (with A/C) Part #3931826 - "HV" - 325 lbs/in
F41 (all) - Part #3832518 - "EA" - 550 lbs/in.
cc
Old Feb 13, 2008 | 03:04 AM
standup's Avatar
standup
So really what you are saying is you have no clue.....
Ronaldo.....I've done the conversion of my SB Vette to a 454 BB, and you will DEFINITELY need to upgrade your front springs....I lost 25mm of ride height in the front after installing the 454, and this made the oil pan way too close to the ground....I would also recommend that you upgrade the rear sway bar....
I had the suspension, brakes and steering rebuilt while it was still an SB, so, in my opinion, the handling with the 454 is much, much better....especially at wide open throttle and the upper MPH ranges....the added weight in the front seems to make it hold the road better....but in saying that, it's also harder on the brakes....
Don't look for excuses to not do the conversion.....the torque of a big block is an amazing thing
Old Feb 13, 2008 | 04:10 AM
Ronaldo's Avatar
Ronaldo
Nice... I don't care if I have to change the front springs. Im going to rebuild the suspension anyway before I put a new engine in it. I just wanted to know if the car handles like **** with a BB. Thats what I have been told.
I already have a big block rearend/single fuellinje, so maybe the car was a big block originally.
Old Feb 13, 2008 | 07:16 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The bigger question is whether or not you have the budget for a BB, as IMHO the available performance makes the weight comparison moot if you go with alum heads (~75# savings vs. iron)...
I've had 3 sharks, all BB's. One was a '69 L71 427. Another was a '70 ZR1 that was re-engined with a 427 before I bought it. And my SA has had one BB or another in it most of it's life (two 427's, and a 496 in the works). I wouldn't have it any other way.
If it's handling you want, you'll be fine if you do your homework before getting to work on your suspension. Don't be afraid of stiff springs.
Old Feb 13, 2008 | 07:18 AM
Durango_Boy
But did you convert from an all iron SBC to a mostly aluminum BBC? According to his first post, and the difference in parts, I don't think he'll have the kind of weight increase you experienced when you did your swap. I would be interested to see the actual weights but he is either very close to same weight, maybe even a hair under.
Old Feb 13, 2008 | 07:43 AM
L88Plus's Avatar
L88Plus
Not to hijack, but how much lighter is a full aluminum LS engine than a stock cast iron block/heads/water pump, aluminum intake 350? That's the direction I'm headed, looking for both big power and good handling.
Old Feb 18, 2008 | 03:35 PM
VIPERBARON's Avatar
VIPERBARON
Default Aluminum heads weight
25 pounds each for aluminum heads with springs & valves, no rockers or studs. I haven't remived the cast iron heads yet to weigh them.
Old Feb 18, 2008 | 04:00 PM
L88Plus's Avatar
L88Plus
Complete cast iron heads are around 72 - 75 lbs apiece, I ship 'em all the time, so that's one number I'm familiar with.
Viperbaron, be careful if you're planning to swap big block heads in-car, those heavy suckers are tough to handle and can do plenty of damage to fiberglass in the blink of an eye.
Old Feb 18, 2008 | 04:02 PM
VIPERBARON's Avatar
VIPERBARON
I'm building a whole new motor; 383 stroker. I kept the original 350 and it's sitting in the corner of the garage. I can't afford the gas in a BB!
To weight difference BBC/SBC?
Old Feb 18, 2008 | 04:15 PM
TheSkunkWorks
The 3x2 427 I had in my SA got significantly better mileage than the L82 350, at least when I could keep my foot out of the secondaries.
Old Feb 18, 2008 | 04:24 PM
Zychron's Avatar
Zychron
You are saying that a BB with aluminun heads and intake will be "very close or even a hair under" an all iron SB?
Think you need to do some homework
Old Feb 18, 2008 | 04:55 PM
rihwoods's Avatar
rihwoods
My 69 GM 502 crate falls in between my 78 L-82 SB and an iron block/head 427 weight..
Rich
