Vortec Intake Manifold Bolts
Old Feb 11, 2008 | 02:24 PM
maggie82's Avatar
maggie82
Default Vortec Intake Manifold Bolts
Has anyone had any luck finding intake bolts for a vortec setup other than a vender. Most places have a set for 30 dollars and the hardware stores bolts have too small or heads. Any suggestions?
Old Feb 11, 2008 | 02:37 PM
DZRick's Avatar
DZRick
Have you check a place like http://www.hiawathafasteners.com/home.html
Not sure if there is one in your area but I would think a company that deals only in nuts and bolts would be able to help you out. Google fasteners in Wisconsin, see what comes up.
Old Feb 11, 2008 | 02:40 PM
spedaleden's Avatar
spedaleden
Try this http://www.gardner-westcott.com/
They ship fast
Old Feb 11, 2008 | 02:41 PM
crazywelder's Avatar
crazywelder
The correct bolts are shouldered to allow a precise amount of gasket compression before bottoming out, ensuring a correct installation every time as long as you use the correct gaskets as well. Torque is 11 ft lbs. This is modern tech, to do the job as designed you need to use the right parts.
Old Feb 11, 2008 | 04:25 PM
Durango_Boy's Avatar
Durango_Boy
I'm sure any GM dealership parts counter can get you a set of intake bolts. Just get a set for a car or truck you know has a Vortec engine...like a 1997 Tahoe.
To Vortec Intake Manifold Bolts
