Alignment tool??
Old Feb 11, 2008 | 08:32 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Alignment tool??
Sometime last year someone posted in here about a tool they made to setup Tranny/Differential alignment. It was a plate that mounted on the Tranny/Differential yoke and had a rod mounted in the center. Alignment was done to set the two oposing rods paralell. I am looking for the specs, bolt pattern etc used to make the plates.
I am way to spastic to be under there trying to do this with a string.
TIA
Old Feb 11, 2008 | 08:57 PM
'75's Avatar
'75
This is not the one you mentioned but maybe will help.
http://forums.corvetteforum.com/show...ght=easy+drive
Old Feb 11, 2008 | 10:55 PM
croaker's Avatar
croaker
Do a search for Forum I.D. frank24 he has a post that mentions your rods
To Alignment tool??
