AFAIK it could be a 2 or 4 bolt, but either would be fine. Some feel that factory 2 bolt blocks are actually stronger, but it really doesnt matter with a street engine. A 355 is just a .030 overbore with a stock crank (3.48 stroke); a 383 is actually stroked with a 3.75 stroke crank.
i was thinkin bout doing cams, heads, rebuilt the engine and supercharge it.
heads and cams from trick flow
maybe a summit crank and piston combo with all the gaskets
and a weiand supercharger the one for just under 2 grand. (if anyone else knows a low profile supercharger id be interested in knowing)
