Jim Shea - Yet another rag joint question.
I've read your paper and also the AIM procedure on aligning the shaft to the gearbox I have a simple question.
In the AIM's mandatory installation sequence (1971 AIM) in step 2 is says to loosely assemble support (U) to the bracket (T). After this it says to install the column in the car. My question is if the support (U) was never removed or loosen is it safe to say the column is aligned properly? It appears to me that this is the main "adjustment ****" for alignment to the gearbox. I have test fitted everything finger tight and it looks to be very well aligned. I know when I go to install the column permanently I should check it out better since I should take into account the body mounts that have settled over the 30+ years. BTW I am installing a new GM rag joint.
John
jeff
I would think that adjusting Support U and Bracket T will have more to do with aligning your column so that it is central in the instrument cluster opening. There is no reason to expect that the alignment to the instrument cluster changes with a column installation.
Now if you have to move Bracket T you may affect the alignment to the steering gear.
Jim
Like I said I am using your paper to replace it I just wanted to be sure and do it correctly after looking at the AIM is where my question came up. I'll check the pins as soon as I get it together.
Thanks to all.
John
