frame question
Dave
http://www.vetteproducts.net/
Tube frames are a whole different ball game using late model suspension and driveline components.
Dave
The first question which you may already know is what do you want to accomplish (longer term) and how much you want to spend. Yes, improve handling/steering/traction, but to what end.
There are many stock frame replacement available, both steel and stainless steel. There are replacements with conversions for C4/5 style front and rear suspensions, and there are tube-frames that utitlize later suspensions (and/or drivetrains and engines).
I went with the tube frame from SRIII Motorsports (www.sriiimotorsports.com). Many have used the "Street Shop" Frame. Then there are also good used stock frames available.
A complete rolling tube frame with suspension and rear is going to run about 10-13k depending on what work you can do yourself. The StreetShop stock style replacement with C4/5 Suspension will probably be close to that and perhaps someone who has used one can chime in.
I would read through many of the posts both here and in the C1/2 forum where there are many threads on the subject of replacement frames. There are pros and cons to each choice, so I would become very informed before making a purchase.
Whether you can do the work yourself or have to farm it out will of course have a big impact on cost.
My SRIII
I will probably just keep the motor naturally asparatied (sp?) wether I keep the small block or go with a big block. Need advice on upgrades for the suspension and steering to if anyone can chime in. I will be doing as much of the work as I can. Thanks again.Dave
