Best Rear Seal
Old Feb 13, 2008 | 08:58 PM
76 VETTE's Avatar
76 VETTE
Default Best Rear Seal
I know to use the one piece Felpro oil pan gasket on my 76- 350 but what rear main seal should I use?I have seen single lip ,double lip and offset lip. I assume I have the single lip now. The engine had been rebuilt 1000 mi. ago. It leaks at rear main now.Thanx in advance....Dale
Old Feb 13, 2008 | 09:44 PM
Durango_Boy's Avatar
Durango_Boy
First, inspect the butt of the crank? Can you see or feel a groove with your finger? The seal will actually cut a small groove int he crank, and even with a new single lip seal this is where a lot of oil leaks out.
If you have the groove, then You can replace it with an offset lip seal, or a double lip seal. I think the double would be best, but part of it will still ride in the groove.
Old Feb 13, 2008 | 10:02 PM
76 VETTE's Avatar
76 VETTE
Thanx Db ,I don't have the pan off yet.I am just assuming that with over 100k on the engine that the crank had a grove .I didn't know if the double seal or off-set is better.I had it rebuilt but I think the builder just put a single lip in it. It leaks pretty good .
Old Feb 13, 2008 | 10:04 PM
Durango_Boy
Either will be better than the single lip seal.
One other thought...are you sure it's the rear seal and not the back of one of the valve covers leaking a little down the back of the engine?
Old Feb 13, 2008 | 10:49 PM
noonie's Avatar
noonie
Old Feb 13, 2008 | 11:07 PM
76 VETTE's Avatar
76 VETTE
Default rear seal
Yes, I tracked it with inspection cover off it only leaks when engine is shut-off.which is the best pan seal ? Mr.gasket for 47.99 or felpro for 23.99?Both are the one piece.Thanx
Old Feb 13, 2008 | 11:09 PM
76 VETTE's Avatar
76 VETTE
Default rear seal
Originally Posted by noonie
Nice pics Noonie. thanx
Old Feb 14, 2008 | 04:28 AM
Stroker-427's Avatar
Stroker-427
One tip.....
When you will install your new real seal, do not aligne the two faces with tha faces of the main cap...... rotate the seal of some 10-15° .... it will help a lot!
Old Feb 14, 2008 | 08:35 AM
Durango_Boy
You won't be able to use a one-piece rear main seal. Your block calls for a two piece and you can't convert unless you pull your engine block and replace it with an '83 or later I think.
Old Feb 14, 2008 | 11:34 AM
76 VETTE's Avatar
76 VETTE
I was refering to the one piece pan seal.I know the rear main is the 2 piece .
Old Feb 14, 2008 | 09:05 PM
jackson's Avatar
jackson
Once you get pan off ... stop there & have an expert determine what seal you have now and if it's installed right. If install OK maybe you need the other seal or maybe crank rougher than usual. Heck you might have an offset and need a double or vsv etc etc. Don't speculate on it now ... have a pro get in there & determine what's required. Just because 10 guys on the internet tell you red marbles are best .... that don't mean it's so ... maybe they're going on rumor & some personal experience ... maybe not.
Old Feb 15, 2008 | 07:46 AM
Durango_Boy
Gotcha. I personally like the Fel-Pro seals best. Also, another possibility, is the guy who did the previous work may have install one half or even the whole rear main seal backwards.
Old Feb 15, 2008 | 12:06 PM
76 VETTE's Avatar
76 VETTE
Default rear seal
I did get a Felpro oil pan seal from AZ . The only rear main they carry is a ROL seal made in Canada.It was the double lip.It has the same # as the seal in Noonie's post.Black in color though.I still don't have the pan off yet to see whats going on .I have read to turn the seal a few degrees when in and some archive posts say no rtv and other say use rtv.Thanx everybody.
Old Feb 15, 2008 | 02:45 PM
76 VETTE's Avatar
76 VETTE
My car is up on blocks and the weather up here is too nasty to to take it anywhere to have a pro look at it.I would think it was installed correctly because the builder had been doing it for over 30 years.I think it might have failed early because car was in a flood.Since then the car has been restored and the engine runs great. Thanx fo the input.
Old Feb 15, 2008 | 02:48 PM
76 VETTE's Avatar
76 VETTE
Is there a paper on this subject anywhere?Searched the archives and just found little odds and ends on this subject.
Old Feb 21, 2008 | 12:20 AM
happiedazs's Avatar
happiedazs
Default leaking rear seal
I too had my rear seal replaced last year when having a valve job done and now it leaks worse than before they replaed the seal. They said they would re-do the job, but if they couldn't get it right the first time ------- IS there any step by step procedure laid out with pictures in case I want to do this job myself? Any tips or any special type of seal I should buy in order to make this job a success the second time around?
Old Feb 21, 2008 | 01:17 AM
Retro78's Avatar
Retro78
Felpro Fluoroelastomer or Viton is the way to go. But expensive....about $25.
To Best Rear Seal
Old Feb 21, 2008 | 01:41 AM
RIJVETTES's Avatar
RIJVETTES
I've got the same problem--leaks worse since the rebuild. I gotta try the double lip seal, since the OEM ain't workin after 2 trys.
Old Feb 21, 2008 | 08:15 AM
Durango_Boy
There is a step by step layed out by a few of us, but no pictures that I recall. It's not a hard task...I did mine in about an hour, but it involves unbolting the idler arm and dropping the suspension a bit so the pan can come off.
Old Feb 21, 2008 | 09:47 AM
bojangies46's Avatar
bojangies46
nine times out of ten it is the oil pan gasket not the rear main oil seal like most people think, check the bolts first and oil pan gasket
