Plug Wire Help
Old Feb 16, 2008 | 10:00 PM
Sidepiper's Avatar
Sidepiper
Default Plug Wire Help
I did an extensive search on the forum and have my AIM book on order. I bought new plug wires and was wondering If I will need to go under the car to re-route the new wires as they were from the factory. Also do I need to remove any of the shielding? Can all routing be done from the top of the motor without removing anything. Thanks Again.
Old Feb 17, 2008 | 12:08 AM
SIXFOOTER's Avatar
SIXFOOTER
Its a huge pain in the ***. You will have to get under there to take a bolt out of the lower shielding to get the old wires out (unless you cut them) and get the new ones in.
I deleted all that stuff and routed them on top
Old Feb 17, 2008 | 07:36 AM
Sidepiper's Avatar
Sidepiper
I think I'm going to route them on top as well. Thanks
Old Feb 17, 2008 | 08:00 AM
jim2527's Avatar
jim2527
NO!!! Dont take the easy way out! It looks so much better when they're run properly. Its more work but the results are worth it. So what, you have to remove some sheilding and work underneath. A 7/16" socket or 2 is all it takes.
1. You need to run the front 2 wires on each side through the motor mounts. This can be done without unbolting them. Lub up the distributor boots with silicone lube, slide them off and the wires will feed through. Re-install boots.
Front wires go through lower 'boomerang shield' and clip into the oil pan clips...my car didnt have the lower boomerangs...
Through the motormounts:
Oil pans clips:
Up from the bottom:
From the top:
Neatly routed to the cap:
Old Feb 17, 2008 | 08:02 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Oil pans clips:
Up from the bottom:
From the top:
Nice write up.
Old Feb 17, 2008 | 08:54 AM
Sidepiper's Avatar
Sidepiper
Jim, Should I take the front wheels off?
Old Feb 17, 2008 | 08:58 AM
jim2527's Avatar
jim2527
I didnt. I put it up on jackstands. From the bottom everything is as clear as day. The only thing you need to do from the top is feed the front 2 wires through wires through the motor mounts. You'll crawl under there and say, 'dam, this isnt to hard'!
Old Feb 17, 2008 | 09:37 AM
Ganey's Avatar
Ganey
The ig. shielding is for reducing radio noise. No radio or using spiral core wires allows the shielding to be removed.
I like the wires underneath - remember heat rises.
Old Feb 17, 2008 | 09:52 AM
schmegeggie's Avatar
schmegeggie
Do it the right way. It is a PITA, and takes more time, but the end result is much better.
Old Feb 17, 2008 | 10:46 AM
Sidepiper's Avatar
Sidepiper
Sweet, Thanks for the motivation, I'm doin it the REAL way
Old Feb 17, 2008 | 11:16 AM
Jud Chapin's Avatar
Jud Chapin
Keep 'em original!
Old Feb 17, 2008 | 11:38 AM
SeattleC5's Avatar
SeattleC5
Oil pans clips:
Up from the bottom:
From the top:
If you are going to install original style wires, then take the time to route them in the factory ignition shielding, which can be easier fron undernear in some areas of the engine. It may take you an extra hour or two, but it looks good and works right. Have fun!
Old Feb 17, 2008 | 02:35 PM
Ironcross's Avatar
Ironcross
As nearly everyone has suggested, they really cant improve on the original location's for neatness and simplicity .....
Out os site, out of mind
Old Feb 17, 2008 | 02:44 PM
jim2527's Avatar
jim2527
A few more pics:
Passengers side coming out of the motor mount and into the oil pan clips:
Passengers side up through the lower barcket:
Drivers side showing wires coming from motor mount, into oil pan clip and up through the lower wire support
One more from the drivers side:
Old Feb 17, 2008 | 03:12 PM
Sidepiper's Avatar
Sidepiper
Thanks Alot for the great pics, Jim!
To Plug Wire Help
