Small block questions
Old Feb 17, 2008 | 09:21 PM
RHBROWN's Avatar
RHBROWN
Default Small block questions
I just purchased a 75 with a new small block. Here what the engine is. An 04 gm short block 300/350 4 bolt block. A edlbrock cam with gear drive and erson 1.5 roller rockers. The heads are gm cast with screw in studs and angle plugs (#8991492). ZZ4 intake and holley 650 double pump. It has a richmond super t-10 4 speed and 410 rearend.
Ok the engine has a oil leak at the oil pan. I was going to remove the engine and reseal the pan next week. Im not sure I like the gear drive. So im thinking of removing the gear drive and then started thinking of changing the cam. First I wanted to try and find out what these heads are cause I was also looking and the Edlebrock head/intake/ cam combo.
Old Feb 17, 2008 | 09:33 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
These are great "Old School" Performance heads. The newer chamber designs are better and some of the newer heads flow better but these are good. Probably flow as good as the performer heads. If your block is a 2004 block a Roller cam might drop right in. That would be a good upgrade. I would get rid of the gear drive too!
3991492....70......350..........LT1,Came l hump,accessory holes,64cc, straight plug
3991492....70-up................over the counter,Camel hump,64cc, straight or angle plug.
Old Feb 17, 2008 | 09:51 PM
ram100987's Avatar
ram100987
Definitely go roller if its a late model Block.
Don't mean to steal the thread but why is the gear drive not better than a chain?
Old Feb 17, 2008 | 10:30 PM
63mako's Avatar
63mako
Gear drive works fine. Matter of personal preference, I don't like the noisey ones.
Old Feb 17, 2008 | 10:31 PM
RHBROWN's Avatar
RHBROWN
I think the gear drive to to much friction. I may be wrong.
What would be a good cam and intake to use?
Old Feb 17, 2008 | 10:35 PM
RHBROWN's Avatar
RHBROWN
The block # on the vin pad is 1m0907 with 5vp under that.
To Small block questions
