Barry Grant TripleD induction for SBC?
Old Feb 19, 2008 | 10:45 AM
sting66cp's Avatar
sting66cp
Default Barry Grant TripleD induction for SBC?
Anyone using this system?
Any feedback?
Old Feb 19, 2008 | 11:08 AM
tigers123's Avatar
tigers123
It would be hard for me to get over the price of the system. It isn't that it doesn't look cool, but can it really beat all inductions systems for performance? Call me a tight ***, but I think with a properly matched intake and single carburetor you meet or exceed anything this system will do for you based on the bang for a buck theory. In other words use the money you saved from not buying this system for something else on the car.
Old Feb 19, 2008 | 11:25 AM
lvrpool32's Avatar
lvrpool32
I had one, loved it, looked good, sounded good, performed well....
Nick
Old Feb 19, 2008 | 12:18 PM
sting66cp's Avatar
sting66cp
Nick
What did you have it installed on? What did you do for hood clearance?
Any pictures?
Old Feb 19, 2008 | 01:22 PM
annicorvette's Avatar
annicorvette
Im looking at this for my 69 also--with the same questions.
Old Feb 19, 2008 | 01:23 PM
wgbsigns's Avatar
wgbsigns
i have one on my BB chevy. like it and it looks cool and runs well. but my motor would have dynoed with more power with a single carb im sure. and saved me money, but it defineatly looks cool. if i were to do it again i would have saved the money and went with single carb.
Old Feb 19, 2008 | 01:55 PM
Roughrider's Avatar
Roughrider
Triple induction systems are meant for one thing...to look cool. For all intents and purposes their sole reason for being is advertising and promotion and making you feel like your equipped like John Holmes. I say that and I own a '69 427/435 L71 with factory three deuces.
Many tests have been run over the years showing a properly matched and set up four barrel system makes more power, is far simpler to live with and easier to keep adjusted.
The Barry Grant Six-Shooter is awesome looking and I'm sure it runs fantastic, but for the same money I'd rather install fuel injection, which is what I did on one of my cars.
Basically, it's your car and your money. If installing the three deuces makes you happy, go for it!
Old Feb 19, 2008 | 02:03 PM
davidarborg's Avatar
davidarborg
SixShooter BB package: 494 HP
540 lb-ft torque
VERSUS
Single 4-bbl Speed Demon 850: 455 HP rpm,
518 lb-ft torque
according to barry grants website?
looks great:
Old Feb 19, 2008 | 02:12 PM
Aggitated Monkey's Avatar
Aggitated Monkey
I think it should fit well under some of our hoods as it looks to be low profile. I like it
Old Feb 20, 2008 | 02:29 AM
llew71BB's Avatar
llew71BB
does anyone know if this will fit a BB under the stock BB/LT1 hood?
Old Feb 20, 2008 | 09:01 AM
wgbsigns's Avatar
wgbsigns
it barly fits under my L88 hood with 2" filter it came with 3" filter. so no it will not fit BB LT1 with a filter on it. maybe without one, maybe
Old Feb 22, 2008 | 09:13 AM
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
My recommendation would be to contact the vendor for questions about this product. As they are not a supporting vendor, they have no posting privileges and cannot respond to threads.
Old Feb 22, 2008 | 08:28 PM
terry82's Avatar
terry82
is it the best or cheapest no ,but the wow factor is great.
Old Feb 23, 2008 | 03:10 AM
davidarborg
How about adapting the original tripower baseplate/filter unit which is pretty low?, would look great IMO
Old Feb 23, 2008 | 03:04 PM
l88rocket's Avatar
l88rocket
Unless you just want the looks I hardly doubt it will perform better than a single 4 barrel
Old Feb 23, 2008 | 03:41 PM
davidarborg
In theory it would, just like 4 Webers, would be nice to try it out
Old Feb 23, 2008 | 09:08 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I don't know about that. I changed out my tarantula intake and Holley double pumper for an old school rochester setup and it was much more responsive and got great mileage (over 20 MPG W/ 4 spd and 3.55 gears). I liked it so much I built a 816 CFM unit for my new 383. You might give up a few peak HP in some applications but throttle response and street manners are awesome! Look at the corvette 3X2 setups. They were rated higher HP than the 4 bbl's with all else being the same.
To Barry Grant TripleD induction for SBC?
Old Feb 23, 2008 | 10:20 PM
b71vette's Avatar
b71vette
Makes sense to me that throttle response would be better than a single 4barrel as the fuel source is closer to each of the cylinders.
Old Feb 24, 2008 | 01:44 PM
63mako's Avatar
63mako
Here is some interesting information fron the Pontiactripower.com website:
Is a tripower better than a four barrel?
I take my information from the June 1995 issue of High Performance Pontiac. The article is entitled, "Four Barrel vs. Tri-power." The authors employed the services of Jim Taylor to assist. They took a well performing 68 GTO, 428 car, 4 speed with slicks. All launches were made at 1200 rpm and shifts at 5200. Car went throught the traps at 5400-5500 rpm.
The Q-Jet had was dialed in on the car. It was equipted with Edelbrock jets, rods, and high-flow needles. In other words, this carb was modified slightly to match the needs of the car.
The 66 tripower was stock except that the choke plate in the center carb was removed and the jets were replaced with 70s in the center and 72s in the ends.
Three runs were made with each set-up. Results:
- Q-Jet tripower
run 1 13.28/101.7 12.93/103.9
run 2 13.33/101.5 12.92/103.8
run 3 13.29/101.8 12.89/104.1
AVERAGE 13.30/101.66 12.89/103.93
The author calculates the 2.27 mph gain to a 22 hp gain over the 4 bbl. He attributes the gain to the tripower's shorter and straighter intake runners and its greater CFM flow.
Old Jun 10, 2008 | 06:47 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
So has anyone successfully fit this under their SBC hood? In the latest issue of Corvette Fever a guy fits this under his '62 hood using an air filter assembly from a '67 BB.
I'm definitely interested in running this set up, but its gotta fit under the stock hood. Anyone?
