'79 brake problem.....HELP!
Old Feb 19, 2008 | 10:30 PM
DI2FLY's Avatar
DI2FLY
Default '79 brake problem.....HELP!
My brake pedal goes to the floor.
I have replaced the pads, rebuilt the calipers, new master cylinder, and YES I BLED the daylights out of the brakes. The brakes will stop you, but you can push the pedal far enough to touch the floor, and the brake warning light comes on.
I need some good ideas, my wife is upset that she can't drive it, and the nagging needs to stop....
Old Feb 19, 2008 | 10:38 PM
justasbad's Avatar
justasbad
just replaced a caliper on mine had a bad piston and now they are better, i would check for leaks take calipers off and check the pistons. you can rule out power booster if thats what it was it would be really stiff pedal. then if no leaks go for the master cylinder.
Old Feb 19, 2008 | 10:43 PM
wombvette's Avatar
wombvette
If the warning light comes on, there is still air in the system.
Old Feb 19, 2008 | 10:44 PM
Durango_Boy's Avatar
Durango_Boy
I think you may have a suspect master cylinder or air in the lines. I know you said you bled and bled, but air can sometimes be caught IN the master and IN the calipers in large pockets.
Try bleeding again, but this time use check valve bleeders that don't let air in around the threads, and tap the calipers and master with a wooden handle to dislodge any air bubbles.
If that doesn't help then I would remove the master, rebuild it, and try again after bench bleeding.
Old Feb 20, 2008 | 10:03 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Sounds like air in the system to me, too.
Old Feb 20, 2008 | 11:46 AM
timbo79's Avatar
timbo79
It is likely air. Follow the correct bleeding sequence on the calipers. I would use a pressure bleeder as well. Using the old wife in the car hitting the pedal doesn't really work on these cars.. that's why I bought a pressure bleeder many yerars ago!
Old Feb 20, 2008 | 11:57 AM
marshrat99's Avatar
marshrat99
I've had the same problem with my 79. Having someone pump the breaks while I bled the system didn't get it. Out of frustration, I gave up and let the car sit overnight. The next day, I gravity bled all lines. Took a while but cured the problem. I agree that air must have been trapped some where and the normal pumping didn't push it out. Maybe sitting overnight allowed the air to better collect somewhere.
Old Feb 20, 2008 | 12:19 PM
SIXFOOTER's Avatar
SIXFOOTER
The warning light is telling you there is air in the system. Letting it sit over night might help and gravity bleeding might be the way to go. Sometimes its stuborn. Watch carefully to see if you get air.
Old Feb 20, 2008 | 12:36 PM
tommyleea's Avatar
tommyleea
If you pump the brakes, does the pedal get better? If so, you have air. If not, you must have a leak someplace; internal or external.
Was the pedal good before you changed the brakes?
Tommy
Old Feb 20, 2008 | 08:21 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Did you bench bleed the Master?
gotta bench bleed the master HmmmHmmm...
Old Feb 20, 2008 | 10:32 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
are you sure that the rod that goes into the master cylinder is adjusted correctly? have some one take the top off the master cylinder and then push on the brakes gently........note when the first bubble pops up......if its not almost immediate then you need to lengthen the rod....you may also have air but i'm guessing that your push rod length needs adjustment. it should have about 1/8 -1/4" travel or so.
Old Feb 20, 2008 | 10:55 PM
yellovette's Avatar
yellovette
I had exactly the same problem. (I know this is going to generate disagreement), BUT, I'll bet it's your vacuum Booster.
I changed: Rotors, pads, master cylinder, proportioning valve, & bled the living daylites out of the system, and it wasn't til I changed the
f-----g vacuum can, that pedal came up nice and high.
There! I've said it.
YV
Old Feb 22, 2008 | 10:00 PM
bobs77vet's Avatar
bobs77vet
so how did you make out????????
Old Feb 23, 2008 | 10:11 PM
Recon12thman's Avatar
Recon12thman
i had the same problem on my 80 i found the left rear caliper was bad at the pistons guess it was rebuilt poorly.... so i replaced it and put speed bleeders on all the calipers bled the system with a motive power brake bleeder from jegs which everyone recommends on this site and now its all good. now im waitin on uncle sam to for SS brake lines to firm them up the rest of the way and look into slotted and cross drilled rotors.
To '79 brake problem.....HELP!
