While I have the rad out , I was thinking about upgrading cam. Engine is stock L48 w/ true duals , no headers,no cat ,no smog . What would be a good cam selection ? L82 cam?
TIA
I am looking at the eddlebrock performer cam and lifter kit. It's only 120 bucks, and looks right up my alley. Make sure you replace the main bolts, though. Or your crank might decide to go for a walk in the park....THAT is my biggest fear with this L48. Too much torque, not enough main bolts...and buy buy motor. What is your power goal? Mine is 350-400.
Thats just total overkill. You have nothing to fear with a Performer cam and a 2-bolt main.
You can check out Summit's cams, Scroggin Dickey sells the same kit as well.
For a low compression L-48 you'll want to keep your duration short and with the stock exhaust manifolds you'll want a cam with a wider LSA for less overlap. Look over the SUM-K1102 kit and maybe the K1103 kit for a L-48. If you are ambitious, you can also replace the stock head gaskets with a Fel Pro 1094 to gain a bit more compression. Don't forget to have the distributor recurved, it is the biggest bang for the buck improvement you can make.
TIA
A very good cam is the GM 151 camshaft. A set of springs and retainers from a 70 LT1 installed and your in fat city. ....
I Have An 80 L82 Went With Comp Cam Extreme Energy 262 I Have Headers And True Duels Very Responsive It Has Excellent Vacuum You Will Not Be Disappointed
We used to use the 204/214 hyd cam (made by most everyone) but we've found that the small extreme energy grinds from Comp give you the improved mid range and top end that the stock cam lacks and low torque either stays the same or improves. The 204/214 cam tends to be a bit soggy on the bottom end and leaves you wanting more at higher RPMs.
I agree, I put a Summit 1102 in my L48 last year to hold me over until the 383 is built. Its a nice upgrade over stock. I'm running it with the Summit 165cc SBC heads (which are Dart Iron Eagle SS) and a Weiand 8004 manifold. Its a nice setup for a mild upgrade.
-Mark.
I'm not adding bolts, I am just replacing the stock ones with ARP main bolts. Do you think that would not be necissary? After the cam, I will be running with new headers, new intake, new carb, and new air filter. Plus 2.5 inch true duals, with no carbs. I figure this just HAS to put at the 300hp range. Which will tide me over till I get done with doing suspension work, and get started working on a plan for the 350-400 hp goal.
I think you are over estimating a realistic HP goal with just a cam, header, intake change with a low compression L48 (approximately 8.25:1). You'll be better off keeping the 750 cfm capable Q-jet and just swapping out the intake with a Performer. You might get to 250 crank HP with all the changes. Yes, changing out main bolts is a waste of time and money at this point. The motor won't see much over 5,500 RPM at this time anyway. Don't forget to recurve the distributor.
I already recurved it, aka Mr Gasket, lol. I bought a new carb because my old had been rebuilt, but incorrectly, and had problems. Thanks for the info on the main bolts.....another guy told me I should...so that is what put it into my head.
From: Graceland in a Not Correctly Restored Stingray
IMHO you'll need better flowing, smaller chamber heads for more compression to get to 300+. If/when you take that step you can always go back in and change the mains to studs at that time, but I wouldn't worry about it otherwise. Caution: should you over-cam with your low CR you'll be very disappointed, so I'd err on the small side.
